Review: WS International WS24095 240cm prime focus dish antenna
Specifications:
REFLECTOR
Model: WS24095
Type Prime
Diameter 240 cm
Panels (sections) 6
Aperture Efficiency 70% min.
C – Band Gain @4.0 GHz 35.89 dB
KU – Band Gain @12.5 GHz 45.54 dB
F/D Ratio 0.38
Focus Length 682 mm
Material Steel
Finish Polyester Powder Coating
Color Grey / Cool Grey
MOUNTING
Mounting Type Ground Mount
Elevation Angle Range 0° - 90°
Azimuth 0° - 360°
Material Steel
Pole Diameter Acceptable 75 mm
Net Weight 29.0 kg
ENVIRONMENT
Operational Winds 25 m / sec
Survival Winds 40 m / sec
Ambient Temperature -40°C ~ +60°C
Relative Humidity 0 ~ 100 %
Introduction:
Last December 2009 WS International (WS International Wholesale Satellite Distributor and Supplier of Free To Air (FTA), MPEGII, DVB Satellite Equipment) offered this 240cm prime focus dish antenna at a special price including FREE shipping. I made a deal with my wife that if she bought me this dish for Christmas I would in return buy her a new laptop and she accepted.
Product Strengths:
• Dish arrived in good shape and was well packaged.
• Robby from WS International provides excellent service and support.
• Dish assembled easily even though the 1 page manual lacked detail.
• 12 reinforced plates came with the dish that adds greater support to the panels. (Please note that the manual now only shows 6 reinforced plates)
• Elevation bar has an additional bolt in addition to the knob bolt to firmly secure the elevation adjustment. (Please note that the manual no longer shows an additional bolt)
• Base is well designed and is made of heavy gauge steel.
• For the price this dish is highly recommended.
Product Weaknesses:
• Center panel stabilizer is too short and is difficult to install. I had to bend the ends out in order to secure. Please see the attached pictures.
• Feed support arms should be bent near the rim of the dish in order to fit correctly. Mine arrived straight and had to be bent in order to curve around the rim of the dish panels. They also overlap on the raised rim of the dish panels making it difficult for the short hex-head cap screw to be secured with the nut. Attached pictures show the gap this creates.
• Three mounting clamps were provided. I feel the base should be secured using at least four mounting clamps for added strength during high winds. (Please note that the manual now shows 4 mounting clamps) Robby was kind enough to provide me with additional mounting clamps for my installation.
• Manual lacks installation details and photos.
Final Thoughts:
Even though this dish has a few weaknesses, it has many strengths that make this dish a great value and I recommend it highly to anyone looking for a 240cm dish antenna.
Pictures:
Specifications:
REFLECTOR
Model: WS24095
Type Prime
Diameter 240 cm
Panels (sections) 6
F/D Ratio 0.38
Focus Length 682 mm
Material Steel
MOUNTING
Azimuth 0° - 360°
Material Steel
Net Weight 29.0 kg
ENVIRONMENT
Introduction:
Product Strengths:
Product Weaknesses:
Final Thoughts:
Pictures:
