Am radio interference question.
solarvic
265
155
Hadley, pa.
I have a completely blind friend that see/s complete darkness. So he listens to his AM FM radio to be connected with the world. His brother installed a led ceiling light in his kitchen and now he can,t get the local am stations when the light is turned on. The radio is a portable sony am fm cassette radio. So am asking if anyone knows how to solve the interference problem or if there is some kind of filter to get for him. As long as the light is turned off the radio works fine. The only way he knows if the light is on is feeling the switch position.
Radioguy41
2,813
2,823
Lehighton, PA
He's getting RFI off of the built in switching power supply. The only way to get rid of it is to get a better LED light (or go back to an incandescent light fixture).
Reactions: FTA4PA
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
26,931
7,281
EM75xb
Agreed, these things are nice, but can cause grief.
solarvic
265
155
Hadley, pa.
I guess the lite had the old florescent tubes in it. His brother removed the ballast and installed led tubes in the same fixture. I will go look at his light to be sure. Thanks for the reply,s.
KE4EST
Staff member
HERE TO HELP YOU!
26,931
7,281
EM75xb
Have done this to a couple of mine. Didn't have to remove the ballast, these tubes were designed to use existing hardware.
arlo
1,254
856
North Eastern
Those LED simple swap tubes are going to cause a ton of RFI.
What you really need is a conversion kit with a separate power supply. That's what I did with the 24" fluorescent's in my kitchen.
It requires a bit of wiring but not too difficult. My buddy has a garage full of LED's that you just slap in and go. One by one they fail.
Tore a few down to see if there is a fix. They have a cheap current limiter pc board about as big as a half stick of chewing gum.
His AM radio that gets the local radio station is obliterated with static and buzzing.
Just for giggles I turned on an AM radio in my kitchen (don't really listen to it at all) and flipped on the lights. No buzz or static.
Reactions: KE4EST
KE4EST
Staff member
HERE TO HELP YOU!
26,931
7,281
EM75xb
Yep, I found that out! I was skeptical, but tried them anyway.
I just got spur of the moment while in Home Depot to try them out. They sure have a long way to go on those things. :)
Radioguy41
2,813
2,823
Lehighton, PA
I've installed some of the complete LED fixtures and those seem to be OK, I'm not getting any RFI from them. Even some of the inexpensive single and double fixtures from Walmart have worked out OK for me down in the tractor shed. Yeah, those replacement FL to LED bulbs just cause havoc and don't last.
arlo
1,254
856
North Eastern
These are the kind I used. 2 years strong no issues. The magnets are kind of 'hinky' so i used a dab of 5 minute epoxy on them too.
Radioguy41
2,813
2,823
Lehighton, PA
All mine are internal and none generate noise. What's giving these things a bad rep are the conversion kits. While some may last the biggest complaint I see are those external regulators going bad prematurely. We've had multiple people over on another forum asking where to buy just the regs, and if it was worth it, because theirs failed.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,819
17,768
Cheshire CT
If your friend sees nothing at all, he certainly doesn't need the light on. Is it just for his brother to be able to see?
solarvic
265
155
Hadley, pa.
He lives by himself but Likes to have the light on so his house doesn,t look abandoned. Guess he likes the light on when friends that have vision come to visit.or take him places. He does turn off the light in the daytime so he can use the radio.
New 50 KW station near ABQ?
[Massachusetts] Herstige Rock Station Sold to EMF
