antenna signal
Is there currently (3/2/24) a broadcast issue? My TV advises me that the is no signal. My antenna and cable appear to ba as usual but I'm not recieving anything.
IF your antenna has a plug-in power supply, make sure it's still plugged in. Or if so, make sure the power supply is still putting out power to the antenna.
Reactions: comfortably_numb
Start at the antenna checking connections all the way to the TV. Is you TV on the right input? Does your TV have a digital tuner? You may need to rescan channels.
ChannelCallsignNetwork
(1278396)
Community
of License
StateMapTransmitter
Distance
(Miles)
Direction
(True)
Direction
(Magnetic)
Field Strength
(dBuV/m)
Signal
Margin
(dB)
Repack
Info
23‑1 (22)​
KAEF-TVABCARCATA
CA​
15.8
162.6°​
148.6°​
94.80 Good​
55.24​
13‑1 (11)​
KEETPBSEUREKA
CA​
15.7
162.6°​
148.6°​
94.41 Good​
58.41​
28‑1 (28)​
KBVUFOXEUREKA
CA​
15.8
162.6°​
148.6°​
92.03 Good​
51.89​
41‑1 (32)​
K32OI-D3ABNEUREKA
CA​
15.7
162.6°​
148.6°​
90.28 Good​
49.77​
29‑1 (29)​
KECA-LDCW/MyEUREKA
CA​
15.8
162.6°​
148.6°​
89.94 Good​
49.71​
13‑1 (24)​
KEETPBSFortuna
CA​
36.6
184.7°​
170.7°​
81.84 Fair​
42.08​
The transmitter is only 15 miles away. You could almost use an indoor antenna. As long as there is no issue with the transmitter. You may have had power outage to the transmitter during the latest storm.
WCMU Fire
