This is a review of the WSI ESX521 Ku Standard LNBF, comparing it to the DMSI JSC321s Standard Ku LNBF. Both are considered hot performers in the Ku LNBF market at this time: June 2011.
Both claim a noise figure of 0.2dB. The ESX521 has a conversion gain rating of 70-75dB, while the JSC321s is rated at 50dB gain by the mfg.
The dish used for this test is a WSI model WS7630, 76cm in size. SES1@101w was chosen for signal comparison and rating, since it has a stable signal at my location, and I have a clear view of it from my backyard test bench. The receiver is a Coolsat 6000 with the latest aftermarket true FTA software loaded. Ten feet of RG-6 coax cable with as-new connectors was used.
The weather was broken clouds with no surface wind, and the ambient temperature was 65 degrees F.
This test was done at the request of WSI, who furnished their LNB included in the test. The ESX521 was tested at the beginning of the session, and again at the end, to minimize differences caused by changing atmospheric conditions or satellite signal strength. There was no difference in signal Quality level recorded at those two times, about 45 minutes apart.
Every effort was made to fine-tune dish aim, LNBF position in holder, and skew for each LNBF and transponder tested.
SES1@101w
Transponder 12060H. ESX521-69%Q, and JSC321s-72%Q
Transponder 12120V. ESX521-69%Q, and JSC321s-74%Q
Finally, for comparison and discussion, an older Grundig 0.8dB rated Ku Standard LNBF was also tested today on SES1. The results are as follows: 12060H-74%Q, and 12120V-73%Q.
Your results may vary. I can only report what I recorded in careful testing.
![LNBs.jpg LNBs.jpg](https://satguys.nyc3.cdn.digitaloceanspaces.com/data/attachments/51/51113-5f3505a9b3889b5187126d894323fc52.jpg)
![LNBs3.jpg LNBs3.jpg](https://satguys.nyc3.cdn.digitaloceanspaces.com/data/attachments/51/51112-c052bcd6f7f12cfc70b5d6fa15b70366.jpg)
![dish.jpg dish.jpg](https://satguys.nyc3.cdn.digitaloceanspaces.com/data/attachments/51/51114-2415d02abe462c2f468cefb93119ed14.jpg)
![Grundig.jpg Grundig.jpg](https://satguys.nyc3.cdn.digitaloceanspaces.com/data/attachments/51/51115-4ac20f608925a2e48c9e4282d2649ddd.jpg)
![sky.jpg sky.jpg](https://satguys.nyc3.cdn.digitaloceanspaces.com/data/attachments/51/51116-d5a49ddc38634f4a21e6b6f3089ff72a.jpg)
I was unable to post to the review section. Moderators please move it there if desired.
SES1@101w
![pencil.png](http://www.satelliteguys.us/images/misc/pencil.png)
