My timers ALWAYS set up using a single channel. I go to the show I'm interested in, hit select, and set up the timer options (all eps, new eps, daily, etc), and save the timer. The show then only records on that channel, and the same show on other channels does not show up in the list.I wish you could create a timer that was specific to channel #. For example I like to record on HBO on the alternate feed at a later time. If I select NEW for a series I get the HBO feed on 300 as expected I would like to be able to select to record all NEW of an episode on 303 only so that it record at a later time. This feature would also eliminate a lot of the timer counts for shows that show up on multiple stations.
I wish there was a way to do what I've just described and tell it to record the show from whatever channel it appears on.
Also, for someone that asked earlier, I have a 622. I'll check the number of events tonight (both with and without skips displayed).
