The last time I did a calculation for two MINI LNBs on an 84e, they fit about 3° apart.
That was with 'em touching, side by side.
And regardless if one is a little higher than the other, they can't get any closer together than side-by-side.
Without grinding, that is.
edit: that was based on published pictures, not calculations discussed below.
Now, I didn't have an 84e to test on, so I can't say for certain that you wouldn't get some signal.
And maybe enough to make you happy.
Filing them down or grinding a bit off the side of each, should do it, as a last resort.
By all means give it a test drive, if that's what you want!
You'd want to find the proper skew for each LNB before proceeding, too.
If you had a dish with a longer focal length (like a
6 foot Prodelin offset) , then the distance between LNBs is bigger for a given number of degree spacing of the birds.
That's one reason I want to get such a dish, and put a whole rack of skinny LNBs out in front of it.
The larger Channel Master (Primestar) dishes with the three long LNB support arms (maybe only in 1.0m and 1.2m sizes), look to have a long focal length.
There are simple calculations we can do to see what the required spacing for 2° birds would be.
Just need the focal length
I hate to state the obvious, but if the MINI is 1½ inches in diameter (40mm), then the closest center-to-center spacing of two of 'em, would be 1½ inches.
So, if you find that your 2° birds focus closer together than that, then something's gotta give.
