Widgets Phase 2 Testing: Instructions & Issue Reports
A couple things, Directv isnt working on this 24/7. They probably take the weekend off. I don't know if the R22 is part of widget, we'll ask. Is anyone not having an HR2x receiver show on the website? I understand R22 are not showing, but haven't heardof any missing HR.
H series do not do widgets as far as I know, if they are showing just ignore them.
Jason here is a quote from your original post at the start of this thread.
"Widgets are only available on the HR2* and the R2* series. (They are not available on the D1*, H2*, R*, or any other DIRECTV DVR)"
My HR20-700 still doesn't show (in fact, nothing shows) in the drop-down on the widget site. No problem logging in or viewing the widget selection.
The reponse I got is that the R22 will be supported, but they still need to update some stuff for the widget site.
They weren't sure why the H receivers are showing, but are working on it.
For anyone that hasn't registered for widgets yet, please include your forum name on the registration - it makes it much easier for DirecTV to tie issues to receivers/accounts.
I must be missing something.... I'm number 802 but I can't log into the widgets site. I enter my email and password and get "your login attempt was not successful, please try again".
I added an RSS feed, but it doesn't show up. All I'm getting is the welcome widget so far.
Are you sure it was the right receiver? The website is also showing some receivers that can't do widgets (h series)
The Widget SDK templates DO NOT WORK!
:eek:I understand that the current Widget SDK does not work, and DirecTV is working on one that may work!
:downCannot publish: get
11:01:24,078 INFO [TemplateWidgetHandler] action requested is ##:--> updateWidget
11:01:24,078 INFO [BusinessManager] calling execute in Business Manager.. with action : updateWidget and publishing : true
11:01:24,078 INFO [BusinessManager] Taking backup of deployed_widgets.xml .
11:01:24,593 INFO [WidgetDeployer] deployed widgets count before undeploy is 1
11:01:24,968 INFO [WidgetDeployer] deployed widgets count after undeploy is 0
11:01:25,187 INFO [WidgetDeployer] deployed widgets count before deploy is 0
11:01:25,187 INFO [WidgetDeployer] parameters as below
11:01:25,390 INFO [WidgetDeployer] widget deployed successfully.
11:01:25,390 INFO [WidgetDeployer] deployed widgets count after deploy is 1
11:01:25,593 INFO [CatalogUpdater] count of deployed[1] and published[1] widgets are equal
11:01:25,593 INFO [CatalogUpdater] deployed and published widgets do not match
11:01:25,593 INFO [CatalogUpdater] publish required
11:01:25,781 INFO [CatalogUpdater] new widgetinfo created
11:01:25,843 INFO [WebServiceManager] calling updateClient Widget in webService manager, action addWidget
11:01:25,890 INFO [WidgetTransformer] Refresh Rate : 20
11:01:25,890 INFO [WebServiceManager] Adding widget images ...
11:01:25,890 INFO [WebServiceManager] webImage image file pathC:\Documents and Settings\Raymond Polone\Desktop\EighterFromDecatur.png
11:01:25,890 INFO [WebServiceManager] dockImage image file pathC:\Documents and Settings\Raymond Polone\Desktop\EighterFromDecatur.png
11:01:25,890 INFO [WebServiceManager] detailImage image file pathC:\Documents and Settings\Raymond Polone\Desktop\EighterFromDecatur.png
11:01:25,937 INFO [WebServiceManager] calling addClient athttp://widgets.directv.com/services/ClientService
11:01:35,390 ERROR [WebServiceManager] For input string: "true"
11:01:35,390 ERROR [BusinessManager] For input string: "true"
11:01:35,390 ERROR [TemplateWidgetHandler] For input string: "true"
11:01:35,390 INFO [TemplateWidgetHandler] xsl file created
11:01:35,468 INFO [AuthenticationService] before p010ne
11:01:35,468 INFO [AuthenticationService] cookie name : JSESSIONID , 1iwxlw7smshuz
11:01:35,468 INFO [AuthenticationService] after p010ne
11:01:35,468 INFO [WidgetDeployer] Getting categories..
11:01:35,468 INFO [WidgetDeployer] get the xsl from : http://192.168.1.101:5001/common-widgets/template/RSSFeed.xsl
11:01:35,468 INFO [WidgetDeployer] connection to context[/common-widgets] opened
:confused:
Solved. Not sure why, but using my user ID (not my e-mail address) works.
Yes, my HR22's are not in the list on the website.
Widgets Phase 2 Testing: General Discussion
HR2x / R22 CE Release 11/28
