2nd receiver moved to separate dish
gip
40
If I have a second receiver and am going out of town for a while, can I take that receiver and connect it to a new dish in the temp location and they will both work?
Jimbo
Cutting Edge
Jul 14, 2005
68,876
7,229
NW Ohio - Buckeye Country
If your using like equipment, yes.
Meaning , if you take a HD DVR with you and want your mpeg 4 channels, your other location will need the proper dish set up.
If it's just standard equipment you'll be good to go.
gip
40
Thanks Jimbo.
charper1
Bourbon Tester
18,442
6
I'm Nationwide
If the temp location is outside your normal market AND you are trying to receive regional programming; you MIGHT be outside the coverage area and not be able to receive it.
gip
40
So what your saying is that I should be able to get everything but hd locals?:confused:
atp1313
1,094
Goose Creek, SC
If you leave the spotbeam coverage, yes. And spotbeams vary in size depending on your home market. So if you are only going a few miles down the road, you are likely going to be fine. If you are going several states away, you are likely SOL.
National feeds should not be affected...
