I was just fooling around with the Azbox, and apparently did something that it didn't like, and had to reboot it.  When it came back up, I couldn't see the menus behind the video.  Ie, I'd have to switch to a channel that didn't have a signal to see the menus. Rebooted a couple times, didn't help.  Finally went into the menu, and saw that it was set to NO TRANSPARENCY, which I assumes means what it says, so I changed that setting to 40 (it has a range from NO to 10 to 50), and it was slightly better, I could just barely read the menus.  So I changed it to 10, and it was almost but not quite back to where I had it before.  Then I went back in and changed it to where it originally was, ie NO TRANSPARENCY, and now it is back to where I had it before.   Strange, it's sort of like the setting got corrupted, but it was still showing the setting I wanted, but had the wrong data.  Luckily setting it to something else, then re-setting it fixed it.
