Controlling TV volume with the HR24 remote
Dennis Brown
SatelliteGuys Guru
Feb 6, 2008
123
I have used the on-screen commands to program my HR24 remote to control the functions of my Sony HDTV. After going thru the scenario, the menu says it worked and I can control the TV's volume with the remote. However, after I leave the on-screen command section, the HR24 no longer controls the volume.
Does anyone know what I doing wrong, if anything.
Thanks and aloha and mahalo from the Big Island
Dennis
Dennis
Dennis,
Go back into your remote set up and re run the set up, there are more than one set of codes, I would try running it and when it tells you that it found one , did it work(it probably found the one you just tried ) say NO and it will look for the next code and run the program ... then try it again and see if that worked.
I'm not sure if there is a setting for manual programming or not.
Fwiw, the D* remotes are very nice and work well.
Don't forget you can also set it for RF incase line of sight is an issue for you.
Sorry Elway, but I haven't had trouble with my remotes either :)
With extra signal added to the volume commands coming out of the directv remotes makes the signal unrecognizable to the recent sony tv's. While in program mode this extra signal is absent.
with receiver off, just program remote like so:
1. tv
2. press and hold MUTE & SELECT, wait for two blinks, release
3. enter 1 0 0 0 0
If the volume still doesn't work try the following:
1. press and hold MUTE & SELECT, wait for two blinks, release
2. enter 9 7 3
3. press CH UP
at last resort:
1. tv
3. enter 9 9 3
4. press SELECT
Dennis,
I tried all 23 Sony codes without success. I wish I could use my old Dish remote. It was easy to program. I give up. I'll continue to use my TV remote together with the Directv turkey.
Thanks everyone for your help.
Dennis
Dennis
Dennis,
Edmond is the Remote Guru.
Try what he says and let us know.
1. tv
3. enter 1 0 0 0 0
2. enter 9 7 3
3. press CH UP
at last resort:
1. tv
3. enter 9 9 3
4. press SELECT
Thanks Edmund.
The "10000" option worked. Is there any way I can control the volume of another TV that it is in a remote location not in sight of the receiver.
Thanks again.
Dennis
Are you asking if you can use the remote with two tv's on the same remote? You can have two different tv programmed to the same remote, but only one volume will be punched through to the directv device, you could set up two identical sat receivers with volume coming from a different tv each.
so the remote would be programmed thos way:
Dtv device: sat receiver with volume from TV device
AV1 device: same sat receiver with volume from AV2 device
AV2: remote tv
Tv: main tv
tell me if you wish it programmed this way?
Edmund:
After implementing the "10000" option, the DIRECTV remote now controls the volume of my Sony TV, which is in the same room as the DIRECTV receiver.
I have split the HD signal from the Sony (via an HDMI cord and powered HDMI splitter) and routed it to a Visio TV in another room. My question is can I program the same DIRECTV remote (maybe using the AV1 or AV2 settings) to control the volume of the Visio TV.
Thanks,
Dennis
The DIRECTV remote now control the volume of all three of my tv's.
Again, Thanks everyone.
Dennis
