D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 12/7/2011 6:01pm - 46 changes
Uplink Comparison Range: 12/07/2011 05:46P - 12/07/2011 06:01P
Channel Additions:
589 - ANTPR [MPEG2 SD] added to Echostar15 61.5W TP 21 ConUS beam (A)
597 - TVBSL [MPEG2 SD] added to EchoStar15 61.5W TP 14 ConUS beam (A) (H)
598 - RBTI [MPEG2 SD] added to Echostar15 61.5W TP 21 ConUS beam (RBTI (Brasilero)) (A) (H)
609 - SPRTV [MPEG2 SD] added to EchoStar15 61.5W TP 14 ConUS beam (A) (H)
737 - KINOE [MPEG2 SD] added to Echostar15 61.5W TP 21 ConUS beam (A) (H)
767 - RELIG [MPEG2 SD] added to Echostar15 61.5W TP 21 ConUS beam (A) (H)
817 - SIC [MPEG2 SD] added to EchoStar15 61.5W TP 29 ConUS beam (A) (H)
6822 - UP5 [MPEG4 HD] added to EchoStar15 61.5W TP 27 ConUS beam (Virtual Channel) (NA)
Channel Removals:
6830 - ANTPR (A) (H) [MPEG2 SD] removed from Echostar15 61.5W TP 21 ConUS beam
6831 - TVBSL (A) (H) [MPEG2 SD] removed from EchoStar15 61.5W TP 14 ConUS beam
6832 - RBTI (A) (H) [MPEG2 SD] removed from Echostar15 61.5W TP 21 ConUS beam (RBTI (Brasilero))
6833 - SPRTV (A) (H) [MPEG2 SD] removed from EchoStar15 61.5W TP 14 ConUS beam
6834 - RELIG (A) (H) [MPEG2 SD] removed from Echostar15 61.5W TP 21 ConUS beam
6835 - SIC (A) (H) [MPEG2 SD] removed from EchoStar15 61.5W TP 29 ConUS beam
6836 - KINOE (A) (H) [MPEG2 SD] removed from Echostar15 61.5W TP 21 ConUS beam
Channel Moves:
8873 - WJAN [MPEG4 SD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:West Palm Beach, FL-Miami, FL-IND) (A) (H)
5280 - WGXAD [MPEG4 HD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-N/A) (A) (H)
5281 - WMAZ [MPEG4 HD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-CBS) (A) (H)
5282 - WMGT [MPEG4 HD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-NBC) (A) (H)
5283 - WGXA [MPEG4 HD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-FOX) (A) (H)
5284 - WMUM [MPEG4 HD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Cochran, GA-PBS) (A) (H)
7881 - WGNM [MPEG4 SD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-IND) (A) (H)
7883 - WPGA [MPEG4 SD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Perry, GA-ABC) (A) (H)
5280 - KAQY [MPEG4 HD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-Columbia, LA-ABC) (A) (H)
5281 - KNOE [MPEG4 HD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-Monroe, LA-CBS) (A) (H)
5282 - KTVE [MPEG4 HD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-El Dorado, AR-NBC) (A) (H)
5283 - KARD [MPEG4 HD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-West Monroe, LA-FOX) (A) (H)
5284 - KLTM [MPEG4 HD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-Monroe, LA-PBS) (A) (H)
5285 - KETZ [MPEG4 HD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-El Dorado, AR-PBS) (A) (H)
7815 - KMCT [MPEG4 SD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-West Monroe, LA-IND) (A) (H)
5200 - WCHS [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Charleston, WV-ABC) (A) (H)
5201 - WOWK [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Huntington, WV-CBS) (A) (H)
5202 - WSAZ [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Huntington, WV-NBC) (A) (H)
5203 - WVAH [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Charleston, WV-FOX) (A) (H)
7319 - WQCW [MPEG4 SD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Portsmouth, OH-CW) (A) (H)
7321 - WPBY [MPEG4 SD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Huntington, WV-PBS) (A) (H)
7322 - WOUB [MPEG4 SD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Athens, OH-PBS) (A) (H)
7325 - WPBO [MPEG4 SD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Portsmouth, OH-PBS) (A) (H)
471 - SPORT [MPEG2 SD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Pay Per View Sports & Events) (A)
605 - ANTEN [MPEG2 SD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Antenna Satellite (Greek)) (A)
640 - TVJPN [MPEG2 SD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (TV Japan SAP) (A)
814 - GLOBO [MPEG2 SD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (TV Globo Internacional) (A) (H)
911 - ANTRA [MPEG AUDIO] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (ANT1 97.2 FM) (A) (H)
9620 - BTV [MPEG2 SD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Business TV) (A)
Transponder Changes:
EchoStar15 61.5W TP 22 ConUS beam 21500 8PSK 2/3 removed
EchoStar15 61.5W TP 26 ConUS beam 21500 8PSK 2/3 removed
Channels in the system: 8373
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2011 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v11.10.31
© 2011 - All Rights Reserved - SatelliteGuys Incorporated.
Channel Additions:
Channel Removals:
Channel Moves:
(FP) = Free Preview
