D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 7/19/2012 4:01am - 90 changes
Uplink Comparison Range: 07/19/2012 03:46A - 07/19/2012 04:01A
Channel Additions:
6844 - UP11 [MPEG4 HD] added to EchoStar10 110W TP 12 Spotbeam 46/47 (Virtual Channel) (NA)
Channel Removals:
4585 - STYLE (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 32 ConUS beam (Style)
4603 - COOK (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 26 ConUS beam
4609 - DIY (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 32 ConUS beam (Do It Yourself Network)
4617 - H2 (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 26 ConUS beam
4623 - AMERI (A) (H) [MPEG4 HD] removed from EchoStar10 110W TP 27 Spotbeam 46/47
4706 - UNIHD (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 31 ConUS beam (Universal HD)
4761 - SPMAN (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 20 ConUS beam
4775 - FSC (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 20 ConUS beam (Fox Soccer Channel)
6806 - UP8 (NA) [MPEG2 SD] removed from EchoStar11 110W TP 22 ConUS beam (Virtual Channel)
6871 - UP29 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 05 Spotbeam A20 (Virtual Channel)
Channel Moves:
8690 - WFTS [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-ABC) (A) (H)
8691 - WTSP [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-St. Petersburg, FL-CBS) (A) (H)
8692 - WFLA [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-NBC) (A) (H)
8693 - WTVT [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-FOX) (A) (H)
8694 - WTTA [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-St. Petersburg, FL-MY) (A) (H)
8695 - WTOG [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-St. Petersburg, FL-CW) (A) (H)
8696 - WEDU [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-PBS) (A) (H)
8697 - WMOR [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Lakeland, FL-IND) (A) (H)
8698 - WVEA [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-N/A) (A) (H)
8699 - WRMD [MPEG2 SD] moved from EchoStar10 110W TP 29 Spotbeam 01 to EchoStar14 119W TP 05 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-N/A) (A) (H)
8700 - WFTT [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-TEL) (A) (H)
8701 - WUSF [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-PBS) (A) (H)
8702 - WCLF [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Clearwater, FL-N/A) (A) (H)
8703 - WXPX [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Bradenton, FL-N/A) (A) (H)
8704 - WXAX [MPEG2 SD] moved from EchoStar10 110W TP 29 Spotbeam 01 to EchoStar14 119W TP 05 Spotbeam A20 (Mkt:Tampa, FL-Clearwater, FL-N/A) (A) (H)
8705 - WWSB [MPEG2 SD] moved from EchoStar10 110W TP 29 Spotbeam 01 to EchoStar14 119W TP 05 Spotbeam A20 (Mkt:Tampa, FL-Sarasota, FL-ABC) (A) (H)
4111 - DIY [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (A) (H)
4113 - COOK [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A) (H)
4115 - STYLE [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Style) (A) (H)
4121 - H2 [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A) (H)
4149 - FSC [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Fox Soccer Channel) (A) (H)
4187 - HMC [MPEG4 HD] moved from Ciel-2 129W TP 29 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Hallmark Movie Channel) (A) (H)
4266 - UNIHD [MPEG4 HD] moved from Ciel-2 129W TP 31 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Universal HD) (A) (H)
4337 - HMC [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Hallmark Movie Channel) (A) (H)
4339 - AMERI [MPEG4 HD] moved from EchoStar10 110W TP 27 Spotbeam 46/47 to EchoStar11 110W TP 19 ConUS beam (A) (H)
4354 - COOK [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
4419 - H2 [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
4422 - DIY [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (A) (H)
4423 - STYLE [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Style) (A) (H)
4585 - STYLE [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Style) (A) (H)
4603 - COOK [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
4609 - DIY [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (A) (H)
4617 - H2 [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
4706 - UNIHD [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Universal HD) (A) (H)
4761 - SPMAN [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
4775 - FSC [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Fox Soccer Channel) (A) (H)
5306 - FSC [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Fox Soccer Channel) (A) (H)
5346 - DIY [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (A) (H)
5514 - ENCOR [MPEG4 HD] moved from EchoStar10 110W TP 27 Spotbeam 46/47 to EchoStar11 110W TP 19 ConUS beam (Encore (East)) (A) (H)
5523 - PIXL [MPEG4 HD] moved from EchoStar10 110W TP 29 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
5524 - UNIHD [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Universal HD) (A) (H)
5530 - HMC [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Hallmark Movie Channel) (A) (H)
5560 - FSC [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Fox Soccer Channel) (A) (H)
5562 - SPMAN [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
5564 - DIY [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (A) (H)
5566 - STYLE [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Style) (A) (H)
5568 - H2 [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
5570 - COOK [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
5576 - HMC [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Hallmark Movie Channel) (A) (H)
5598 - AMERI [MPEG4 HD] moved from EchoStar10 110W TP 27 Spotbeam 46/47 to EchoStar11 110W TP 19 ConUS beam (A) (H)
5910 - DIY [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (NA)
5914 - COOK [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 22 ConUS beam (NA)
5926 - H2 [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 22 ConUS beam (NA)
6868 - UP29 [MPEG4 HD] moved from EchoStar14 119W TP 01 Spotbeam A20 to EchoStar10 110W TP 27 Spotbeam 01 (Virtual Channel) (NA)
9418 - PIXL [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A)
9427 - UNIHD [MPEG4 HD] moved from Ciel-2 129W TP 31 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Universal HD) (A)
9428 - STYLE [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Style) (A)
9444 - HMC [MPEG4 HD] moved from Ciel-2 129W TP 29 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Hallmark Movie Channel) (A)
9447 - COOK [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A)
9483 - SPMAN [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A)
9520 - FSC [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Fox Soccer Channel) (A)
9525 - H2 [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A)
9527 - DIY [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (A)
9605 - STYLE [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Style) (A) (H)
14115 - WEDU2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14117 - WUSF2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14118 - WUSF3 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14119 - WUSF4 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14120 - WXPX2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Bradenton, FL)(NA)
14121 - WXPX3 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Bradenton, FL)(NA)
14122 - WFTS2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14516 - WEDU3 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14902 - WFLA2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14964 - WTTA2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:St. Petersburg, FL)(NA)
15102 - WTSP2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:St. Petersburg, FL)(NA)
15127 - WCLF2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Clearwater, FL)(NA)
15135 - WVEA2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
15179 - WEDU4 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
Transponder Changes:
EchoStar10 110W TP 12 Spotbeam 01 changed from 21500 8PSK 2/3 to 20000 QPSK 5/6
Channels in the system: 8453
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2012 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.04.10
© 2012 - All Rights Reserved - SatelliteGuys Incorporated.
Channel Additions:
Channel Removals:
Channel Moves:
(FP) = Free Preview
