Do you all think I should exchange the 722k? I just feel like how can a receiver start doing this as I only got it on 6/25. What should I do about 612 in bedroom?
Thats a heckuva downgrade.....Is there an issue?
Laddyboy said:You definitely should contact tech support. They'll either ship replacement receivers or send a tech to your home. With problems with both receivers they should want to send a tech. Sign up for the protection plan to get free shipping on replacements or a $15 tech visit. Drop the plan afterwards. Failure to update the guide is sometimes and early warning that the hard drive is heading out the door.
Even though receivers only a few weeks old the hard drive can be heading out?
Tampa8 said:Are you using an ota module on the 722K? If so unplug it and see if the freezes stop. My 612's have been virtually flawless for a very long time. There are so many things to see what the problem is for you it's hard to know where to start. Here are a few;
Be very sure each receiver is well ventilated. Can't stress that enough. If you are not sure ask.
Are you in an older home where there could have an electrical/grounding issue? Even in some newer homes that can happen but more rare.
Are your signals good for each satellite?
If you have an OTA antenna plugged into the 612 unplug that too, just in case there is a problem with the antenna.
I am always suspicious when two receivers in two different locations in the house are freezing or rebooting, makes me think it's not the receivers.
rocket69 said:Back the Truck up ... you had a service call in under the first 3 months of install..? That trip should have been free and even if they did charge you that charge would cover you for another 90 day if just by chance some other part of the system was a fault.
empiretc said:can anyone confirm what causes a loss of credits. Do you only lose them when you drop below at120?
Hi All
Spouse wants us to go back to dtv due to problems. Can we avoid the eft if we downgrade to dish family and keep service at that level? Dish would have to come down as I can't have 2 dishes up. I'm in a apt complex. So dish and receivers would be put away but acct will still be active. Is this possible?
