Virgin Island at 99W
chaskuchar
807
14
saint charles, missouri
it scans in with the solomend s9. info says it is 1080i and h264 and ac3. this is on the 6'. will scan it in with the microhd when the wife lets me use the main tv. charlie
Blindowl1234
2,035
94
SouthWest Ohio
Charlie, Didn't automatically scan in fro me. I've tried manually entering it but something needs to be changed h264 isn't recogized I guess...I'll keep at it haha
I hate getting older as everything has a longer, harder learning curve.
Blindowl1234
2,035
94
SouthWest Ohio
Just went to Ali editor and it shows it as mpeg2...no way I can see to change to H.264, looks like when you scan a channel it defaults to whatever. So I'm more confused..perhaps Brian can shed light on how to do this?
eurosport
In Dave Grohl We Trust!
6,862
311
North Florida
Good signal but no audio or video. Manual PID scan had same result on both my Pansat 9200 and the Coolsat 8000. :( All the others on this transponder play fine.
SatelliteAV
6,486
186
Roseville, CA
In the AliEditor folder open the AliEditor Configuration Settings file and change: Chip Type=M3601s . Save the file then change the file to read only. This should keep the AliEditor software in the correct mode to provide advanced settings.
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
26,918
7,273
EM75xb
Just did this and it worked beautifully,now watching on the microHD....Thanks for that detail Brain. :)
hwm
298
North Central Idaho
I followed the OP's instructions and now have this channel back on my Openbox S10. It would not scan in with a single satellite blind scan or a transponder scan.
Thanks!
chaskuchar
807
14
when i scanned 99w, i deleted all the channels on there except for kcwy13. then scanned 99w with my solomend s9, and it scanned in with the new values. my firmware is hdst 11-03-21. i have tried other firmwares but this one doesn't have the moving dish display when it sees signal and works better for me. charlie
Blindowl1234
2,035
94
SouthWest Ohio
I'm using Pids 769, 770, 769 in the micro hd. Got picture no audio...changed from h264 to mpeg2...changed the chipset to M3601s as well, still no change....How are those of you with the Micro Hd getting the audio?
UPDATE: Forgot to change the audio in the editor to AC3..works now
Cham
VE4GLS
2,550
1,122
Boonies
Although it was easy to edit via the ALI editor, would be nice to be able to edit via the remote (or have it scan in during the blind scan like the AzBox did).
Weird... even though I put in the proper V and A pids, in the info screen it shows an Apid of 8962. Audio is fine though.
northgeorgia
1,557
211
North GA
I haven't even paid attention to this thread much, but to my surprise, I don't have any of the feeds today on the miniBUD. Yesterday, they were there (probably not the NBC one...I didn't pay attention). I'll see what happens in the next couple of days.
northgeorgia
1,557
211
North GA
PR/VI mux is there today on the miniBUD. Couldn't get the changed NBC station or the hidden station, though, even with the ALI editor changes.
eurosport
6,862
311
North Florida
UPDATE:
Deleted everything on 99w in the Pansat 9200 & did a fresh blind scan and the new NBC in HD is there with the others and playing fine! :D
So for others having trouble, a fresh re-scan may do the trick! :)
chaskuchar
807
14
i have deleted all transponders and then rescanned 99w with the microhd. still no nbc. played with various ways of inputting the pids but no success. curious as to why the solomend s9 would scan it in and the microhd can't... i am still a novice at saving a file, editing, and putting it back. so i just skip that nbc for now. i don't know if the solomend scans it in as a dbs-2 transponder. charlie
joeroscoe1957
92
2
Did as you mentioned on my pansat 9200 , all pr mux ch's now there , but just audio for nbc (which is now on tv3 instead of tv4) but no video , other ch's work fine ?? Did you change any scan settings ? I do not have a dvb s-2 board , but do not think it applies here .
UPDATE:
eurosport
6,862
311
North Florida
Strange. No s2 board here either. Just did a fresh "smart scan" after deleting everything on that satellite and there they were.
Sent from my DROIDX using SatelliteGuys
TRG
5,245
7,974
Albuquerque, NM
Iceberg said:
ironically Dish uplinked the ABC & NBC (in HD) now for Puerto Rico subs (not available yet)
CBS is from that "lovely" :rolleyes: WSEE in Erie
No fox yet in HD...but maybe soon?
Oh and before someone says it...no the uplinking of these in HD will not affect us seeing them right now. Dish has had them in SD for a while now (using the same feed as we get) ;)
Is WSEE still FTA?
