PBS mux on 125W moving around...preparing for changes
Mr Tony
2,068
8,363
Mankato, MN
also the 12163 H 4444 and 12169 H 4444 alternate between DVB & DVB-S2 depending on need. MicroHD automatically changes if they do :)
Mr Tony
2,068
8,363
Mankato, MN
Jim those have actually been up since the end of June. The 12060 transponder was just duplicated for affiliates to get changed over to S2
The 12180 transponder is very strong....80 or so on the MicroHD
GrendelT
Sep 30, 2012
10
Texas
Just joined, but saw this thread. Grabbing PBS feeds is my main goal right now.
I was able to secure this Spreadsheet that shows the new channel alignment on AMC21. Came right from a PBS tech himself.
  • Transition RF parameters v7 8- 31-2012.xls
wallyhts
Staff member
HERE TO HELP YOU!
3,218
442
Welcome to satguys :)
Well looks like we lost our full time LPB.
kevingilmore
Apr 7, 2005
20
What is the maximum possible signal quality on tp24
The best I can do is 75% with a signal of 90%
phlatwound
3,327
378
Goosapeak Junction
What receiver are you using?
Different receivers will display different quality percentage readings, when in reality they are receiving the same strength of signal.
And different signal types can require more or less signal strength for a stable lock and view.
tede
85
Toronto Canada
Looks like the 12060 transponder is still there but is completely different,
no channels, very weak and a different coding mode, are they trying
different things? maybe, here is a screenshot : AMC 21- 12060V   SR30000.PNG
Tede
wallyhts
Staff member
HERE TO HELP YOU!
3,218
442
different things? maybe, here is a screenshot :View attachment 81805
Tede
Whats that screen shot from? (PC with DVB card, spectrum analyzer etc..) I may have asked you before if I did sorry i forgot. Plus your cat looks like my best buddy Gizmo the crazy cat that can't hear that has chew more cables then I can count.
n4bbq
152
Dahlonega, Ga
Well this satellite is the only one I can see from my home (trees & such).
Will one of the cheap-@$$ Openbox or Skybox units work ok for getting PBS in DVB-S2?
Blindowl1234
2,035
94
SouthWest Ohio
Iceberg how good of a signal are you getting on the east, west, create channels? I'm only getting about 50% with the MHD. Since the switch, the signal on my 36" Prime* dish is nowhere near the 70% it used to be.
