Updated Dish Anywhere app
MikeD-C05
33,247
31,655
Nederland , Texas
What's wrong? No pairing , app crashes...can you elaborate?
It keeps saying that I need to use a sling adapter or look at their website for tv anywhere information. No matter what I do. The DISH remote access works fine for me, using the same sling adapter that the tv anywhere says I need to add. It will load my timers ,schedule , and shows , but will not let me play anything live or recorded.
papato6
101
9
Kansas
That sounds like normal function. Is she trying to watch tv2 at home when you are using the app? Do you have a sling adapter and were you watching a Live or DVR event?
If it is normal it shouldn't be. 722 is set up in single mode (no tv2 output). Dish App using tv2 tuner and 722 using tv1 or OTA, no control with remote. If I tune to tv2 on the 722 (at the receiver) it kicks the app off (as it should). Yes using sling adapter and doesn't matter what I'm watching with the app, live TV or DVR recording.
lucky86
3,941
179
By the sea, in a land called Honalee
Do you have more than one receiver? Do you have the right one selected in the app? You can verify in the settings option in the app. If you have the correct receiver selected, does it show a green online indicator next to it? Usually this happens when a reciever without a sling adapter is selected from the app or if you have multiple receivers, the wrong one is selected.
lucky86
3,941
179
Does the same thing happen if you put the reciever in dual mode manually and then try to sling via the app?
papato6
101
9
Kansas
Only one receiver has broadband. When I select MyDVR in the App all the correct recordings are there. I like how the guide now shows the OTA channels, which is another indication that it's my 722 it connects to.
lucky86
3,941
179
I was asking that question to Mike. I asked you... Does the same thing happen if you put the reciever in dual mode manually from the front panel and then try to sling via the app?
ggw2000
693
110
Out here somewhere
Wondering if I can ask a quick questions as i have searched everywhere and cannot find the answer. Looking to maybe buy a sling adapter for
my 722K. We have an ipad2 and couple of ipad minis. When we go out of town I assume we can watch anything that we are subscribed to with
dish as long as we have a good wifi connection. My questions are: Does the 722K have to be left powered on in order to use the sling adapter
while not home? Secondly if no one is at home can only one of the ipads access the programming at once or would it be two since 722k is not
being used at home?
Thanks in advance, Gerry
lucky86
3,941
179
being used at home?
The reciever will power up on its own when you start slinging, so no need to leave it powers on.
The sling adapter provides remote viewing for one person at a time. View remotely from two ipads at once , you would need a sling box for tv 1 and your current Sling Adapter for tv 2.
Mike_H
770
5
Twin Cities, MN
being used at home?
722k must be in stand-by and have power. The LED's on the front don't need to be on, though they will turn on as soon as you connect with an external connection.
Only one person can stream from the Sling at a time. So if you have your ipad going, no one else can use theirs on the sling. others can use the dishonline to stream other shows, but not those stored on your dvr. Only the sling connected device can do that.
papato6
101
9
Kansas
being used at home?
Gerry,
With the previous app (pre update) the 722 didn't have to be on, just in standby. As far as using two devices at once. I don't think it will work, but I never tried it.
ggw2000
693
110
Out here somewhere
The reciever will power up on its own when you start slinging, so no need to leave it powers on. The slingbox provides remote viewing for one person at a time. To get both tuners ready to view remotely, you would also need a sling box for tv 1.
Thanks for the reply! Understand the pwr up but hazy on "you would also need a sling box for tv1". Since you plug the first sling adapter into the usb port on the back of the 722k where would you plug a 2nd sling adapter into?
lucky86
3,941
179
Sling adapter for Dish only works on tv2. You would need a stand alone slingbox which connects to the tv 1 video output instead. I have this type of set up. You can see my sling adapter and slingbox. I can have two people remotely viewing at once. See attached.
