D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 7/10/2013 3:47pm - 142 changes
Uplink Comparison Range: 07/10/2013 02:31P - 07/10/2013 03:46P
Channel Additions:
6457(51) - KPPX [MPEG4 HD] added to Ciel-2 129W TP 07 Spotbeam 34 (Mkt:Phoenix, AZ-Tolleson, AZ-ION) (NA)
6342(59) - KPXC [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 19 (Mkt:Denver, CO-Denver, CO-ION) (NA)
5257(48) - KPXR [MPEG4 HD] added to Ciel-2 129W TP 03 Spotbeam 21 (Mkt:Cedar Rapids, IA-Cedar Rapids, IA-N/A) (NA)
6383(16) - KUPX [MPEG4 HD] added to Ciel-2 129W TP 03 Spotbeam 18 (Mkt:Salt Lake City, UT-Provo, UT-N/A) (NA)
6651(9) - WSVF2 [MPEG2 SD] added to EchoStar14 119W TP 05 Spotbeam B16 (Mkt:Harrisonburg, VA) (A) (H)
656 - MBCM [MPEG2 SD] added to Anik F3 118.7W TP 01 ConUS beam (A) (H)
Channel Removals:
6651 - WUSA (A) (H) [MPEG2 SD] removed from EchoStar10 110W TP 25 Spotbeam 05 (Mkt:Harrisonburg, VA-Washington, DC-CBS)
5707 - NIT-H (A) (FP) [MPEG4 HD] removed from Anik F3 118.7W TP 13 ConUS beam
5708 - NIT-V (A) (FP) [MPEG2 SD] removed from Anik F3 118.7W TP 13 ConUS beam
5709 - NIT-M (A) (FP) [MPEG4 SD] removed from Anik F3 118.7W TP 13 ConUS beam
5710 - TEST (A) (FP) [MPEG4 HD] removed from EchoStar11 110W TP 13 ConUS beam
6655 - WSVF2 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 05 Spotbeam B16
9815 - SPRTV (A) (H) [MPEG2 SD] removed from Anik F3 118.7W TP 31 ConUS beam
14780 - WLRN2 (NA) [EPG] removed from EchoStar14 119W TP 04 Spotbeam B20 (OTA EPG:Miami, FL)
Channel Moves:
240 - PRST [MPEG2 SD] moved from EchoStar14 119W TP 15 ConUS beam to EchoStar14 119W TP 16 ConUS beam (A)
240 - PRST [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 21 ConUS beam (A)
265 - CCNEW [MPEG2 SD] moved from EchoStar11 110W TP 08 ConUS beam to EchoStar14 119W TP 16 ConUS beam (A)
265 - CCNEW [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 21 ConUS beam (A)
361 - MAVTV [MPEG4 HD] moved from Ciel-2 129W TP 19 ConUS beam to EchoStar14 119W TP 16 ConUS beam (MavTV HD) (A) (H)
361 - MAVTV [MPEG4 HD] moved from Nimiq5 72.7W TP 26 ConUS beam to Nimiq5 72.7W TP 21 ConUS beam (MavTV HD) (A) (H)
368 - CI [MPEG4 HD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar14 119W TP 16 ConUS beam (Crime & Investigation Network) (A) (H)
368 - CI [MPEG4 HD] moved from Nimiq5 72.7W TP 24 ConUS beam to Nimiq5 72.7W TP 21 ConUS beam (Crime & Investigation Network) (A) (H)
Channel Package Flag Changes:
5190(7) - KATV [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Little Rock, AR-ABC)
5191(11) - KTHV [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Little Rock, AR-CBS)
5192(4) - KARK [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Little Rock, AR-NBC)
5193(16) - KLRT [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Little Rock, AR-FOX)
5194(2) - KETS [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Little Rock, AR-PBS)
5195(42) - KARZ [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Little Rock, AR-MNT)
5196(38) - KASN [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Pine Bluff, AR-CW)
9357(25) - KVTN [MPEG4 SD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Pine Bluff, AR-REL)
9358(49) - KMYA [MPEG4 SD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR)
5150(25) - WJXX [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Orange Park, FL-ABC)
5151(47) - WTEV [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-CBS)
5152(12) - WTLV [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-NBC)
5153(30) - WAWS [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-FOX)
5154(4) - WJXT [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-IND)
5155(32) - WAWSD [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-MY)
5156(17) - WCWJ [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-CW)
5157(7) - WJCT [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-PBS)
9058(8) - WXGA [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Waycross, GA-PBS)
9059(59) - WJEB [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-TRIN)
5290(9) - WTVM [MPEG4 HD] - Echostar16 61.5W TP 03 Conus beam changed to Available (H) (Mkt:Columbus, GA-Columbus, GA-ABC)
5291(3) - WRBL [MPEG4 HD] - Echostar16 61.5W TP 03 Conus beam changed to Available (H) (Mkt:Columbus, GA-Columbus, GA-CBS)
5292(38) - WLTZ [MPEG4 HD] - Echostar16 61.5W TP 03 Conus beam changed to Available (H) (Mkt:Columbus, GA-Columbus, GA-NBC)
5293(54) - WXTX [MPEG4 HD] - Echostar16 61.5W TP 03 Conus beam changed to Available (H) (Mkt:Columbus, GA-Columbus, GA-FOX)
5294(28) - WJSP [MPEG4 HD] - Echostar16 61.5W TP 03 Conus beam changed to Available (H) (Mkt:Columbus, GA-Columbus, GA-PBS)
5295(49) - WLGA [MPEG4 SD] - Echostar16 61.5W TP 03 Conus beam changed to Available (H) (Mkt:Columbus, GA-Opelika, AL-CW)
5190(8) - WQAD [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Moline, IL-ABC)
5191(4) - WHBF [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Rock Island, IL-CBS)
5192(6) - KWQC [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Davenport, IA-NBC)
5193(18) - KLJB [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Davenport, IA-FOX)
5194(36) - KQIN [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Davenport, IA-PBS)
5195(24) - WQPT [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Moline, IL-PBS)
7604(26) - KGCW [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Burlington, IA-CW)
5270(25) - WEHT [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Evansville, IN-ABC)
5271(44) - WEVV [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Evansville, IN-CBS)
5272(14) - WFIE [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Evansville, IN-NBC)
5273(7) - WTVW [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Evansville, IN-FOX)
5274(12) - WNIN [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Evansville, IN-PBS)
5275(31) - WKOH [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Owensboro, KY-PBS)
5276(45) - WEVVD [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Evansville, IN-N/A)
5150(36) - WTVQ [MPEG4 HD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Lexington, KY-ABC)
5151(27) - WKYT [MPEG4 HD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Lexington, KY-CBS)
5152(18) - WLEX [MPEG4 HD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Lexington, KY-NBC)
5153(56) - WDKY [MPEG4 HD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Danville, KY-FOX)
5155(46) - WKLE [MPEG4 HD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Lexington, KY-PBS)
9209(28) - WKYT2 [MPEG4 SD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Lexington, KY-CBS)
9212(65) - WLJC [MPEG4 SD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Beattyville, KY-REL)
5150(3) - WSIL [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Harrisburg, IL-ABC)
5151(12) - KFVS [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Cape Girardeau, MO-CBS)
5152(6) - WPSD [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Paducah, KY-NBC)
5153(23) - KBSI [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Cape Girardeau, MO-FOX)
5154(29) - WKPD [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Paducah, KY-PBS)
5155(8) - WSIU [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Carbondale, IL-PBS)
5156(49) - WDKA [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Paducah, KY-MY)
9262(27) - WTCT [MPEG4 SD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Marion, IL-REL)
9263(9) - WQWQ [MPEG4 SD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY)
9265(32) - WPSDD [MPEG4 SD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Paducah, KY-N/A)
5200(33) - KSPR [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO-Springfield, MO-ABC)
5201(10) - KOLR [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO-Springfield, MO-CBS)
5202(3) - KYTV [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO-Springfield, MO-NBC)
5203(5) - KRBK [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO-Osage Beach, MO-N/A)
5204(27) - KOZL [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO)
5205(21) - KOZK [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO-Springfield, MO-PBS)
5206(15) - KCZ [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO-Springfield, MO-CW)
5190(13) - WLOX [MPEG4 HD] - Echostar16 61.5W TP 20 Spotbeam 62 changed to Available (H) (Mkt:Biloxi, MS-Biloxi, MS-ABC)
5192(6) - WXXV2 [MPEG4 HD] - Echostar16 61.5W TP 20 Spotbeam 62 changed to Available (H) (Mkt:Biloxi, MS-Gulfport, MS-FOX)
5193(25) - WXXV [MPEG4 HD] - Echostar16 61.5W TP 20 Spotbeam 62 changed to Available (H) (Mkt:Biloxi, MS-Gulfport, MS-FOX)
5194(16) - WMAH [MPEG4 HD] - Echostar16 61.5W TP 20 Spotbeam 62 changed to Available (H) (Mkt:Biloxi, MS-Biloxi, MS-PBS)
6591(14) - WLOX2 [MPEG4 SD] - Echostar16 61.5W TP 20 Spotbeam 62 changed to Available (H) (Mkt:Biloxi, MS-Biloxi, MS-ABC)
6401(61) - KZJL [MPEG4 HD] - Ciel-2 129W TP 06 Spotbeam 49 changed to Available (H) (Mkt:Houston, TX-Houston, TX-N/A)
6401(61) - KZJL [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 16 changed to Available (H) (Mkt:Houston, TX-Houston, TX-N/A)
5130(28) - KAMC [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-ABC)
5131(13) - KLBK [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-CBS)
5132(11) - KCBD [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-NBC)
5133(34) - KJTV [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-FOX)
5134(22) - KLCW [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Wolfforth, TX-CW)
5135(5) - KTTZ [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX)
5137(14) - KMYL [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-MY)
5138(46) - KXTQ [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-N/A)
7944(16) - KPTB [MPEG4 SD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-REL)
5170(9) - KTRE [MPEG4 HD] - Echostar16 61.5W TP 22 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Lufkin, TX-ABC)
5171(7) - KLTV [MPEG4 HD] - Echostar16 61.5W TP 22 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Tyler, TX-ABC)
5172(19) - KYTX [MPEG4 HD] - Echostar16 61.5W TP 22 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Nacogdoches, TX-CBS)
5173(56) - KETK [MPEG4 HD] - Echostar16 61.5W TP 22 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Jacksonville, TX-NBC)
5174(51) - KFXK [MPEG4 HD] - Echostar16 61.5W TP 22 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Longview, TX-FOX)
5175(59) - KERA [MPEG4 HD] - Echostar16 61.5W TP 24 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Dallas, TX-PBS)
8887(54) - KCEB [MPEG4 SD] - Echostar16 61.5W TP 22 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Longview, TX-CW)
6382(24) - KPNZ [MPEG4 HD] - Ciel-2 129W TP 03 Spotbeam 18 changed to Available (H) (Mkt:Salt Lake City, UT-Ogden, UT-N/A)
5150(3) - WHSV [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 52 changed to Available (H) (Mkt:Harrisonburg, VA-Harrisonburg, VA-ABC)
5151(9) - WSVF2 [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 52 changed to Available (H) (Mkt:Harrisonburg, VA)
5152(4) - WRC [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 52 changed to Available (H) (Mkt:Harrisonburg, VA-Washington, DC-NBC)
5153(42) - WSVF [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 52 changed to Available (H) (Mkt:Harrisonburg, VA)
5154(51) - WVPT [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 52 changed to Available (H) (Mkt:Harrisonburg, VA-Staunton, VA-PBS)
676 - GEOTV [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam changed to free preview (A) (Geo TV (Urdu))
677 - ARYDI [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam removed from free preview (A) (Ary Digital USA (Urdu))
689 - QTV [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam removed from free preview (A) (ARY Qu'ran TV Urdu (Sunni-Pakistani))
736 - JUS [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam removed from free preview (A) (JUS Punjabi )
9817 - TVINT [MPEG2 SD] - Anik F3 118.7W TP 15 ConUS beam changed to Available (H)
Channel Type Changes:
9732 - RTN32 Anik F3 118.7W TP 09 ConUS beam changed from MPEG4 HD to MPEG4 SD (A) (H)
Channel Renames:
214 - TWC (The Weather Channel) - EchoStar14 119W TP 06 ConUS beam renamed to WEATH (A)
214 - TWC (The Weather Channel) - Nimiq5 72.7W TP 23 ConUS beam renamed to WEATH (A)
4214(214) - TWC (The Weather Channel) - Ciel-2 129W TP 17 ConUS beam renamed to WEATH (A) (H)
4214(214) - TWC (The Weather Channel) - Nimiq5 72.7W TP 11 ConUS beam renamed to WEATH (A) (H)
4345(214) - TWC (The Weather Channel) - Ciel-2 129W TP 05 Spotbeam 1 renamed to WEATH (A) (H)
4345(214) - TWC (The Weather Channel) - Ciel-2 129W TP 02 Spotbeam 55 renamed to WEATH (A) (H)
4473(214) - TWC (The Weather Channel) - EchoStar10 110W TP 20 Spotbeam 48/49 renamed to WEATH (A) (H)
4727 - TWC (The Weather Channel) - EchoStar14 119W TP 06 ConUS beam renamed to WEATH (A) (H)
4727 - TWC (The Weather Channel) - Nimiq5 72.7W TP 23 ConUS beam renamed to WEATH (A) (H)
4728 - TWC (The Weather Channel) - EchoStar10 110W TP 20 Spotbeam 48/49 renamed to WEATH (A) (H)
4728 - TWC (The Weather Channel) - Ciel-2 129W TP 17 ConUS beam renamed to WEATH (A) (H)
4728 - TWC (The Weather Channel) - Ciel-2 129W TP 05 Spotbeam 1 renamed to WEATH (A) (H)
4728 - TWC (The Weather Channel) - Ciel-2 129W TP 02 Spotbeam 55 renamed to WEATH (A) (H)
4728 - TWC (The Weather Channel) - Nimiq5 72.7W TP 11 ConUS beam renamed to WEATH (A) (H)
4929(214) - TWC (The Weather Channel) - EchoStar10 110W TP 20 Spotbeam 48/49 renamed to WEATH (A) (H)
5047(214) - TWC (The Weather Channel) - EchoStar10 110W TP 20 Spotbeam 48/49 renamed to WEATH (A) (H)
5367(214) - TWC (The Weather Channel) - Ciel-2 129W TP 17 ConUS beam renamed to WEATH (A) (H)
5367(214) - TWC (The Weather Channel) - Nimiq5 72.7W TP 11 ConUS beam renamed to WEATH (A) (H)
5537(214) - TWC (The Weather Channel) - Ciel-2 129W TP 05 Spotbeam 1 renamed to WEATH (A) (H)
5537(214) - TWC (The Weather Channel) - Ciel-2 129W TP 02 Spotbeam 55 renamed to WEATH (A) (H)
9438(214) - TWC (The Weather Channel) - Ciel-2 129W TP 17 ConUS beam renamed to WEATH (A)
9438(214) - TWC (The Weather Channel) - Nimiq5 72.7W TP 11 ConUS beam renamed to WEATH (A)
Channels in the system: 8859
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2013 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.09.27
© 2013 - All Rights Reserved - SatelliteGuys Incorporated.
Channel Additions:
Channel Removals:
Channel Moves:
Channel Renames:
(FP) = Free Preview
