7/10/2013 3:47pm - Uplink Activity Report - 142 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 7/10/2013 3:47pm - 142 changes
Uplink Comparison Range: 07/10/2013 02:31P - 07/10/2013 03:46P
Channel Additions:
6457(51) - KPPX [MPEG4 HD] added to Ciel-2 129W TP 07 Spotbeam 34 (Mkt:Phoenix, AZ-Tolleson, AZ-ION) (NA)
6342(59) - KPXC [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 19 (Mkt:Denver, CO-Denver, CO-ION) (NA)
5257(48) - KPXR [MPEG4 HD] added to Ciel-2 129W TP 03 Spotbeam 21 (Mkt:Cedar Rapids, IA-Cedar Rapids, IA-N/A) (NA)
6383(16) - KUPX [MPEG4 HD] added to Ciel-2 129W TP 03 Spotbeam 18 (Mkt:Salt Lake City, UT-Provo, UT-N/A) (NA)
6651(9) - WSVF2 [MPEG2 SD] added to EchoStar14 119W TP 05 Spotbeam B16 (Mkt:Harrisonburg, VA) (A) (H)
656 - MBCM [MPEG2 SD] added to Anik F3 118.7W TP 01 ConUS beam (A) (H)
Channel Removals:
6651 - WUSA (A) (H) [MPEG2 SD] removed from EchoStar10 110W TP 25 Spotbeam 05 (Mkt:Harrisonburg, VA-Washington, DC-CBS)
5707 - NIT-H (A) (FP) [MPEG4 HD] removed from Anik F3 118.7W TP 13 ConUS beam
5708 - NIT-V (A) (FP) [MPEG2 SD] removed from Anik F3 118.7W TP 13 ConUS beam
5709 - NIT-M (A) (FP) [MPEG4 SD] removed from Anik F3 118.7W TP 13 ConUS beam
5710 - TEST (A) (FP) [MPEG4 HD] removed from EchoStar11 110W TP 13 ConUS beam
6655 - WSVF2 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 05 Spotbeam B16
9815 - SPRTV (A) (H) [MPEG2 SD] removed from Anik F3 118.7W TP 31 ConUS beam
14780 - WLRN2 (NA) [EPG] removed from EchoStar14 119W TP 04 Spotbeam B20 (OTA EPG:Miami, FL)
Channel Moves:
240 - PRST [MPEG2 SD] moved from EchoStar14 119W TP 15 ConUS beam to EchoStar14 119W TP 16 ConUS beam (A)
240 - PRST [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 21 ConUS beam (A)
265 - CCNEW [MPEG2 SD] moved from EchoStar11 110W TP 08 ConUS beam to EchoStar14 119W TP 16 ConUS beam (A)
265 - CCNEW [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 21 ConUS beam (A)
361 - MAVTV [MPEG4 HD] moved from Ciel-2 129W TP 19 ConUS beam to EchoStar14 119W TP 16 ConUS beam (MavTV HD) (A) (H)
361 - MAVTV [MPEG4 HD] moved from Nimiq5 72.7W TP 26 ConUS beam to Nimiq5 72.7W TP 21 ConUS beam (MavTV HD) (A) (H)
368 - CI [MPEG4 HD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar14 119W TP 16 ConUS beam (Crime & Investigation Network) (A) (H)
368 - CI [MPEG4 HD] moved from Nimiq5 72.7W TP 24 ConUS beam to Nimiq5 72.7W TP 21 ConUS beam (Crime & Investigation Network) (A) (H)
Channel Package Flag Changes:
5190(7) - KATV [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Little Rock, AR-ABC)
5191(11) - KTHV [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Little Rock, AR-CBS)
5192(4) - KARK [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Little Rock, AR-NBC)
5193(16) - KLRT [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Little Rock, AR-FOX)
5194(2) - KETS [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Little Rock, AR-PBS)
5195(42) - KARZ [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Little Rock, AR-MNT)
5196(38) - KASN [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Pine Bluff, AR-CW)
9357(25) - KVTN [MPEG4 SD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR-Pine Bluff, AR-REL)
9358(49) - KMYA [MPEG4 SD] - Echostar16 61.5W TP 31 Spotbeam 14 changed to Available (H) (Mkt:Little Rock, AR)
5150(25) - WJXX [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Orange Park, FL-ABC)
5151(47) - WTEV [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-CBS)
5152(12) - WTLV [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-NBC)
5153(30) - WAWS [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-FOX)
5154(4) - WJXT [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-IND)
5155(32) - WAWSD [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-MY)
5156(17) - WCWJ [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-CW)
5157(7) - WJCT [MPEG4 HD] - Echostar16 61.5W TP 31 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-PBS)
9058(8) - WXGA [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Waycross, GA-PBS)
9059(59) - WJEB [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 10 changed to Available (H) (Mkt:Jacksonville, FL-Jacksonville, FL-TRIN)
5290(9) - WTVM [MPEG4 HD] - Echostar16 61.5W TP 03 Conus beam changed to Available (H) (Mkt:Columbus, GA-Columbus, GA-ABC)
5291(3) - WRBL [MPEG4 HD] - Echostar16 61.5W TP 03 Conus beam changed to Available (H) (Mkt:Columbus, GA-Columbus, GA-CBS)
5292(38) - WLTZ [MPEG4 HD] - Echostar16 61.5W TP 03 Conus beam changed to Available (H) (Mkt:Columbus, GA-Columbus, GA-NBC)
5293(54) - WXTX [MPEG4 HD] - Echostar16 61.5W TP 03 Conus beam changed to Available (H) (Mkt:Columbus, GA-Columbus, GA-FOX)
5294(28) - WJSP [MPEG4 HD] - Echostar16 61.5W TP 03 Conus beam changed to Available (H) (Mkt:Columbus, GA-Columbus, GA-PBS)
5295(49) - WLGA [MPEG4 SD] - Echostar16 61.5W TP 03 Conus beam changed to Available (H) (Mkt:Columbus, GA-Opelika, AL-CW)
5190(8) - WQAD [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Moline, IL-ABC)
5191(4) - WHBF [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Rock Island, IL-CBS)
5192(6) - KWQC [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Davenport, IA-NBC)
5193(18) - KLJB [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Davenport, IA-FOX)
5194(36) - KQIN [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Davenport, IA-PBS)
5195(24) - WQPT [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Moline, IL-PBS)
7604(26) - KGCW [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 12 changed to Available (H) (Mkt:Davenport, IA-Burlington, IA-CW)
5270(25) - WEHT [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Evansville, IN-ABC)
5271(44) - WEVV [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Evansville, IN-CBS)
5272(14) - WFIE [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Evansville, IN-NBC)
5273(7) - WTVW [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Evansville, IN-FOX)
5274(12) - WNIN [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Evansville, IN-PBS)
5275(31) - WKOH [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Owensboro, KY-PBS)
5276(45) - WEVVD [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Evansville, IN-Evansville, IN-N/A)
5150(36) - WTVQ [MPEG4 HD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Lexington, KY-ABC)
5151(27) - WKYT [MPEG4 HD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Lexington, KY-CBS)
5152(18) - WLEX [MPEG4 HD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Lexington, KY-NBC)
5153(56) - WDKY [MPEG4 HD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Danville, KY-FOX)
5155(46) - WKLE [MPEG4 HD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Lexington, KY-PBS)
9209(28) - WKYT2 [MPEG4 SD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Lexington, KY-CBS)
9212(65) - WLJC [MPEG4 SD] - Echostar16 61.5W TP 05 Conus beam changed to Available (H) (Mkt:Lexington, KY-Beattyville, KY-REL)
5150(3) - WSIL [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Harrisburg, IL-ABC)
5151(12) - KFVS [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Cape Girardeau, MO-CBS)
5152(6) - WPSD [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Paducah, KY-NBC)
5153(23) - KBSI [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Cape Girardeau, MO-FOX)
5154(29) - WKPD [MPEG4 HD] - Echostar16 61.5W TP 29 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Paducah, KY-PBS)
5155(8) - WSIU [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Carbondale, IL-PBS)
5156(49) - WDKA [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Paducah, KY-MY)
9262(27) - WTCT [MPEG4 SD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Marion, IL-REL)
9263(9) - WQWQ [MPEG4 SD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY)
9265(32) - WPSDD [MPEG4 SD] - Echostar16 61.5W TP 27 Spotbeam 35 changed to Available (H) (Mkt:Paducah, KY-Paducah, KY-N/A)
5200(33) - KSPR [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO-Springfield, MO-ABC)
5201(10) - KOLR [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO-Springfield, MO-CBS)
5202(3) - KYTV [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO-Springfield, MO-NBC)
5203(5) - KRBK [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO-Osage Beach, MO-N/A)
5204(27) - KOZL [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO)
5205(21) - KOZK [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO-Springfield, MO-PBS)
5206(15) - KCZ [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 63 changed to Available (H) (Mkt:Springfield, MO-Springfield, MO-CW)
5190(13) - WLOX [MPEG4 HD] - Echostar16 61.5W TP 20 Spotbeam 62 changed to Available (H) (Mkt:Biloxi, MS-Biloxi, MS-ABC)
5192(6) - WXXV2 [MPEG4 HD] - Echostar16 61.5W TP 20 Spotbeam 62 changed to Available (H) (Mkt:Biloxi, MS-Gulfport, MS-FOX)
5193(25) - WXXV [MPEG4 HD] - Echostar16 61.5W TP 20 Spotbeam 62 changed to Available (H) (Mkt:Biloxi, MS-Gulfport, MS-FOX)
5194(16) - WMAH [MPEG4 HD] - Echostar16 61.5W TP 20 Spotbeam 62 changed to Available (H) (Mkt:Biloxi, MS-Biloxi, MS-PBS)
6591(14) - WLOX2 [MPEG4 SD] - Echostar16 61.5W TP 20 Spotbeam 62 changed to Available (H) (Mkt:Biloxi, MS-Biloxi, MS-ABC)
6401(61) - KZJL [MPEG4 HD] - Ciel-2 129W TP 06 Spotbeam 49 changed to Available (H) (Mkt:Houston, TX-Houston, TX-N/A)
6401(61) - KZJL [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 16 changed to Available (H) (Mkt:Houston, TX-Houston, TX-N/A)
5130(28) - KAMC [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-ABC)
5131(13) - KLBK [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-CBS)
5132(11) - KCBD [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-NBC)
5133(34) - KJTV [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-FOX)
5134(22) - KLCW [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Wolfforth, TX-CW)
5135(5) - KTTZ [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX)
5137(14) - KMYL [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-MY)
5138(46) - KXTQ [MPEG4 HD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-N/A)
7944(16) - KPTB [MPEG4 SD] - Echostar16 61.5W TP 23 Spotbeam 17 changed to Available (H) (Mkt:Lubbock, TX-Lubbock, TX-REL)
5170(9) - KTRE [MPEG4 HD] - Echostar16 61.5W TP 22 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Lufkin, TX-ABC)
5171(7) - KLTV [MPEG4 HD] - Echostar16 61.5W TP 22 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Tyler, TX-ABC)
5172(19) - KYTX [MPEG4 HD] - Echostar16 61.5W TP 22 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Nacogdoches, TX-CBS)
5173(56) - KETK [MPEG4 HD] - Echostar16 61.5W TP 22 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Jacksonville, TX-NBC)
5174(51) - KFXK [MPEG4 HD] - Echostar16 61.5W TP 22 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Longview, TX-FOX)
5175(59) - KERA [MPEG4 HD] - Echostar16 61.5W TP 24 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Dallas, TX-PBS)
8887(54) - KCEB [MPEG4 SD] - Echostar16 61.5W TP 22 Spotbeam 15 changed to Available (H) (Mkt:Tyler, TX-Longview, TX-CW)
6382(24) - KPNZ [MPEG4 HD] - Ciel-2 129W TP 03 Spotbeam 18 changed to Available (H) (Mkt:Salt Lake City, UT-Ogden, UT-N/A)
5150(3) - WHSV [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 52 changed to Available (H) (Mkt:Harrisonburg, VA-Harrisonburg, VA-ABC)
5151(9) - WSVF2 [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 52 changed to Available (H) (Mkt:Harrisonburg, VA)
5152(4) - WRC [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 52 changed to Available (H) (Mkt:Harrisonburg, VA-Washington, DC-NBC)
5153(42) - WSVF [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 52 changed to Available (H) (Mkt:Harrisonburg, VA)
5154(51) - WVPT [MPEG4 HD] - Echostar16 61.5W TP 18 Spotbeam 52 changed to Available (H) (Mkt:Harrisonburg, VA-Staunton, VA-PBS)
676 - GEOTV [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam changed to free preview (A) (Geo TV (Urdu))
677 - ARYDI [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam removed from free preview (A) (Ary Digital USA (Urdu))
689 - QTV [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam removed from free preview (A) (ARY Qu'ran TV Urdu (Sunni-Pakistani))
736 - JUS [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam removed from free preview (A) (JUS Punjabi )
9817 - TVINT [MPEG2 SD] - Anik F3 118.7W TP 15 ConUS beam changed to Available (H)
Channel Type Changes:
9732 - RTN32 Anik F3 118.7W TP 09 ConUS beam changed from MPEG4 HD to MPEG4 SD (A) (H)
Channel Renames:
214 - TWC (The Weather Channel) - EchoStar14 119W TP 06 ConUS beam renamed to WEATH (A)
214 - TWC (The Weather Channel) - Nimiq5 72.7W TP 23 ConUS beam renamed to WEATH (A)
4214(214) - TWC (The Weather Channel) - Ciel-2 129W TP 17 ConUS beam renamed to WEATH (A) (H)
4214(214) - TWC (The Weather Channel) - Nimiq5 72.7W TP 11 ConUS beam renamed to WEATH (A) (H)
4345(214) - TWC (The Weather Channel) - Ciel-2 129W TP 05 Spotbeam 1 renamed to WEATH (A) (H)
4345(214) - TWC (The Weather Channel) - Ciel-2 129W TP 02 Spotbeam 55 renamed to WEATH (A) (H)
4473(214) - TWC (The Weather Channel) - EchoStar10 110W TP 20 Spotbeam 48/49 renamed to WEATH (A) (H)
4727 - TWC (The Weather Channel) - EchoStar14 119W TP 06 ConUS beam renamed to WEATH (A) (H)
4727 - TWC (The Weather Channel) - Nimiq5 72.7W TP 23 ConUS beam renamed to WEATH (A) (H)
4728 - TWC (The Weather Channel) - EchoStar10 110W TP 20 Spotbeam 48/49 renamed to WEATH (A) (H)
4728 - TWC (The Weather Channel) - Ciel-2 129W TP 17 ConUS beam renamed to WEATH (A) (H)
4728 - TWC (The Weather Channel) - Ciel-2 129W TP 05 Spotbeam 1 renamed to WEATH (A) (H)
4728 - TWC (The Weather Channel) - Ciel-2 129W TP 02 Spotbeam 55 renamed to WEATH (A) (H)
4728 - TWC (The Weather Channel) - Nimiq5 72.7W TP 11 ConUS beam renamed to WEATH (A) (H)
4929(214) - TWC (The Weather Channel) - EchoStar10 110W TP 20 Spotbeam 48/49 renamed to WEATH (A) (H)
5047(214) - TWC (The Weather Channel) - EchoStar10 110W TP 20 Spotbeam 48/49 renamed to WEATH (A) (H)
5367(214) - TWC (The Weather Channel) - Ciel-2 129W TP 17 ConUS beam renamed to WEATH (A) (H)
5367(214) - TWC (The Weather Channel) - Nimiq5 72.7W TP 11 ConUS beam renamed to WEATH (A) (H)
5537(214) - TWC (The Weather Channel) - Ciel-2 129W TP 05 Spotbeam 1 renamed to WEATH (A) (H)
5537(214) - TWC (The Weather Channel) - Ciel-2 129W TP 02 Spotbeam 55 renamed to WEATH (A) (H)
9438(214) - TWC (The Weather Channel) - Ciel-2 129W TP 17 ConUS beam renamed to WEATH (A)
9438(214) - TWC (The Weather Channel) - Nimiq5 72.7W TP 11 ConUS beam renamed to WEATH (A)
Channels in the system: 8859
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2013 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.09.27
© 2013 - All Rights Reserved - SatelliteGuys Incorporated
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
102,747
26,378
Newington, CT
Congrats to all those folks who now get their locals from the new locations.
Remember however that while these changes were made today, they won't be officially in DISH's computers until tomorrow, so for anyone who needs a dish upgrade you should wait until tomorrow to call in, as today they can not make changes since the changes are not in their computer systems. :D
Hope that prevents some frustration for some members.
harshness
18,889
4,062
Salem, OR
I don't know why they renamed it, TWC is what it is named on most systems now.
I wonder if the channel might be doing their own name change. Perhaps something like Weather.com?
edit: I did some research and found that the parent company of TWC, Weather Companies, changed their name from Weather Channel Companies last October.
donebu
92
37
VanCleave
I'm in the (Mkt:Biloxi, MS) with a DISH 1000 dish, will DISH change it out without a service charge? Are there disadvantages to EA versus WA? Thanks for the information.
Jim5506
8,137
3,497
Slaton, Texas
Even if you keep WA and add a side dish for 61.5, the D1000 would either need a DP44 switch or an upgrade to a D1000.2 WA plus a DP Dual pointed at 61.5 or a D1000.2 EA.
I opted for a WA 1000.2 with a DP dual on my old D500 pointed at 61.5, picture looks good.
I tried to talk the D1000.2 installer into leaving it connected and installing a DP dual when the Hopper was installed, but he cut the cable, so as soon as the uplink was announced, I had them come back and replace the lnb with a DP dual and re-run the cable to the D1000.2 WA dish.
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
102,747
26,378
Newington, CT
Dosent NBC / Comcast own The Weather Channel now?
