Put a portable drill in a vice. Chuck in the laser. Turn on laser - Turn on drill. You'll either get a point of light, or a circle of varying size.using lasers, but gave up when I could not be certain about the 90 degree angle
Was thinking about getting this one,
Should be easy enough to build a holder to get it square and centered. Good enough for rifle bores, good enough for me.
Damn, I knew I might be outted by a real firearms enthusiast. I shall keep this in mind sir !That bore sight will be tapered like the chamber of the rifle it's designed to fit in so that may not be a good idea either. If you can get a straight casing bore sighter like a .444 Marlin or a .45-70 Government round then that might work but the one in the picture is for a tapered chamber rifle.
