If you connect it directly to the client port, run check switch on the hopper, then it should be good to go
Really? A SuperJoey connected directly to the client port on a dual node works? And no other wires?
The dual node Host port works but Dish says the node power consumption is more than the SJ supports, that's why the integrator is the only method they allow.
