Deciding Between Floor Standing Speakers
teachsac
Staff member
HERE TO HELP YOU!
Nov 3, 2005
15,314
1,108
Elk Grove, CA
Well, I've been looking into floor standing speakers for awhile now. Finally narrowing it down to 2 choices:
Paradigm Signature 6 (MSRP $6598/pair): These were my favorites. Very clean and open. Couldn't believe the difference between the next Level down (Prestige) and these.
http://paradigm.com/products-current/type=tower/model=signature-s6/page=overview
B&W Diamond 804s (MSRP $7495/pair): These were a little warmer. Still spectacular sound. Made the CM10s sound like garbage. Didn't really care for the 10s anyways.
http://www.bowers-wilkins.com/Speakers/Home_Audio/800_Series_Diamond/804-Diamond.html
Really tough choice. Plus I'll need to add a matching center.
S~
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,806
17,752
Cheshire CT
I don't have much experience with either, but have listened to a lot of Paradigms over the years and I really like them generally.
navychop
60,092
27,408
Northern VA
Well, I'm a Klipschorn guy, so you know where I stand. I've heard much good about Paradigms. But this post is to plug getting a GOOD center. Made all the difference in the world to me- maybe the most important speaker.
teachsac
Staff member
HERE TO HELP YOU!
Nov 3, 2005
15,314
1,108
Elk Grove, CA
Looking at replacing my RB75s and center.
S~
jayn_j
Press On Regardless
11,003
4,032
Sheboygan, WI
Personally, I stay with some classic Klipsch KG4s from 1990. I have newer towers, but leave them upstairs in the family room.
I think many people pay way too much attention to the L&R at the expense of the center. They worry about the visual impact of the center to the degree that they ignore the sound. How many setups have you seen with large towers holding 12" woofers and 2 horns for the :&R, and then a center with a single horn and 2 5" cones? I see it all too often.
In my mind, this is wasted money. Even with the action adventure films, the majority of the sound comes out of the center speaker. Many movies are 90% center. Your experience is only going to be as good as the weakest link, so why compromise with the speaker that provides most of the sound?
Some day I will redo my theater room and add an acoustically transparent screen. At that point, I will look for a set of classic Klipsch Cornwalls and put 3 behind the screen. Meanwhile, I have to compromise. I can't fit a KG4 below my screen, so I have the next smaller KG3, on its side, with the horn rotated 90 degrees. It is acceptable, but a noticeable compromise.
I guess where I am coming from is to recommend you not only look for series compatibility, but even go so far as buying the center that is billed as 1 step up from your mains. Oh, and make damned sure you get this right before you start buying into the marketing hype about adding 7.1. That's a whole different rant though.
harshness
18,909
4,069
Salem, OR
I'm a big believer in the fewer drivers the better when it comes to centers. Nodes suck and that's why I chose a two-way center (one 6" cone and a small dome). It is a little larger but the sound is more uniform.
navychop
60,092
27,408
Northern VA
....Oh, and make damned sure you get this right before you start buying into the marketing hype about adding 7.1. That's a whole different rant though.
Rant away, I love my 7.1 setup, especially on the extremely rare occasion where they all are put to good use. I probably should get a calendar and mark down when that happens, but to maintain a calendar with so few marks....
<sigh>
Reactions: jayn_j
jayn_j
Press On Regardless
11,003
4,032
Sheboygan, WI
<sigh>
Exactly my rant. Put your money into the other 5. Exception is a very large room where the other 2 can be repurposed for ambience.
jayn_j
Press On Regardless
11,003
4,032
Sheboygan, WI
Yet all the mains being discussed have multiple woofers. This made some sense back in the days of dolby pro-logic where common signals were directed at the center. These days with discrete front channels, the sound engineers will often direct a small amount of sound to the l&R pair to widen the soundstage. Those speakers are a lot further apart and in my mind more likely to generate nodes. I just don't see much from a 200 Hz signal working from a pair of woofers that are separated by 8"
teachsac
Staff member
HERE TO HELP YOU!
Nov 3, 2005
15,314
1,108
Elk Grove, CA
For that money, they should allow you to audition them in your home. That's the only way you're going to know.
That part isn't a problem. I still have my contacts from before I sold my business. Tough part is finding places to audition anymore.
S~
teachsac
Staff member
HERE TO HELP YOU!
Nov 3, 2005
15,314
1,108
Elk Grove, CA
<sigh>
More and more movies are 7.1 now than ever before. Most everything I've purchased recently is 7.1 (Maleficent, Dawn of PotA, Ninja Turtles, etc.). Several even have Atmos tracks. Always putting them to good use in the HT. Even 5.1 and using PL, works well.
S~
gadgtfreek
22,105
865
Lower Alabama
S~
That is here. A lot of the brands like paradigm are found at one shop here, and they wan't an appointment, want to talk about an in home visit. Crap I just do not want to deal with.
gadgtfreek
22,105
865
Lower Alabama
I guess it reminds me too much of buying a car and I have distaste for that. I generally go into a purchase with most of the knowledge I need, just one little piece of the puzzle left (listening/looking/touching). These people want to "used car dealer" the hell out of you and it annoys me. So I haven't been back.
