Still needing a little help
Mr Tony
2,067
8,352
Mankato, MN
I am needing both the VHF and UHF. Any ideas for that, ICE? It's gotta be a decent price range. Thanks
correct but you have 3 station on VHF and are the Big 3. I would try and make sure you can get them
UHF again I would do a 2 or 4 bay antenna. The issue is 2edge and not very good on the tvfool (so obviously terrain). Throw in the fact you are indoors and sure I could say get a badass XG91 but will it achieve results? Unknown
2 bay or 4 bay can be had for under $25 (I got a 2bay on amazon for like $15) and might work (at least better than the indoor antenna)
andy_horton
901
158
Northwest Georgia
andy_horton
901
158
Northwest Georgia
Mr Tony
2,067
8,352
Mankato, MN
yes you can use separate antennas for indoors. Thats what I did in my apartment
http://www.satelliteguys.us/xen/posts/3417756/
as for UHF I posted the info above
andy_horton
901
158
Northwest Georgia
Ok, with an RCA amp my signal strength has dropped from 30's to 10. The other channel that only had a signal strength of 10 is out completely. If I went to RadioShack and bought one of their big time amps would it help the signal since I can get a signal, just a weak one. I think I have found the sweet spot for the indoor spot for the UHF stations. Really starting to piss me off..
spongella
1,625
1,236
Central NJ
Digital TV again as was said is a little bit of voodoo. Now I know why the public has not embraced OTA. More difficult to get channels than when we had analog TV. The other thing complicating the situation is that the TV set is now in charge of what you see, that is, if the signal is not strong enough then it'll most times not show up or be very pixielated. With analog TV at least you got fuzzy signals that you could try optimizing.
Keep up the good work to all of you trying to get decent digital reception, a lot is trial and error. That is how many great inventors and scientists navigated. It is worth the effort, once you get OTA the picture is clear as a bell, nothing like it.
Reactions: andy_horton
jayn_j
Press On Regardless
10,996
4,011
Sheboygan, WI
Well, good luck buying anything at Radio Shack. They closed all their stores last week. Best current bet is Amazon.
I have found the little amps in powered antennas to be less than worthless and they will often reduce signal strength. They are poorly made and fail often. If you need an amplifier, it is best to purchase a quality one from Channelmaster, Winegard or other suppliers, such as:
Amazon product ASIN B000GGKOG8
larrykenney
552
222
San Francisco, CA
Jay wrote: "Well, good luck buying anything at Radio Shack. They closed all their stores last week."
Not all of them. There are two here in San Francisco that are remaining open, and I suspect that's true in some other places. What they're going to have in stock, I don't know, but so far there have been no changes at these two stores. All of the others have big signs up... "Closing... Everything Must Go".
andy_horton
901
158
Northwest Georgia
After trial and error, I found that the rabbit ears I was using had 2 "ports" on the back. One was bad and that was why I couldn't get reception on the UHF channels. Still can't get WFLI 53.1 but I get NBC, ABC, CBS, PBS, and FOX. Plus the subchannels. So all in all I get 11 cannels OTA plus Roku on the net. I guess not bad. But I'm not done working on getting WFLI with a better antenna. Thanks for the encouragement!!
andy_horton
901
158
Northwest Georgia
UPDATE--Found the sweet spots on the channels. One channel comes in when it wants to mostly at night but overall I'm satisfied for now until I order a different antenna. Thanks for all the help and keep chiming in with any help.
Reactions: FaT Air
jayn_j
Press On Regardless
10,996
4,011
Sheboygan, WI
I installed an a/b switch to switch between uhf and vhf. Is this a good idea or will signal strength suffer? Should I just run 2 wires to the tv?
That's going to be inconvenient in these days with auto scanning. Why not combine the signals as close to the antennas as practical. Something like this:
Amazon product ASIN B000Q6AC56They make them in 75 ohm and 300 ohm versions, depending on your needs. 75 ohm is coax as seen on the left, and 300 ohm is flat twin lead as shown on the right. Just go find the model you need.
andy_horton
901
158
Northwest Georgia
UPDATE--WDSI dropeed some with the leaves, but is steady at 20-30%. I'm going to buy another antenna at Amazon or at the Radioshack store still open in this area. WFLI is VERY weak at best but always has been. Do I need a preamp using an indoor/outdoor antenna on the inside of my house?
