Sat2IP for Windows -- Stream from your Amiko Mini HD SE/RE to Windows
MrJoint
May 26, 2015
2
Poland
sat2ip work fine :D
I tested it on Ferguson Ariva 203 is alternative of Amiko HD
only lose my time is not working. Any ideas?
sorry for my english
C:/Program Files/SMPlayer/mplayer/mplayer.exe -noquiet -slave -identify -nofs -sub-fuzziness 1 -vo direct3d, -priority abovenormal -nodr -double -nomouseinput -nokeepaspect -wid 4326354 -monitorpixelaspect 1 -subfont-osd-scale 3 -ass -embeddedfonts -ass-line-spacing 0 -ass-font-scale 1 -noflip-hebrew -ass-styles C:/Users/Artur/.smplayer/styles.ass -subcp ISO-8859-1 -subpos 100 -volume 50 -cache 2048 -osdlevel 0 -prefer-ipv4 -vf-add screenshot -noslices -channels 2 -af-add scaletempo -af-add equalizer=0:0:0:0:0:0:0:0:0:0 rtsp://192.168.1.10:554
MPlayer Redxii-SVN-r37401-4.9.2 (i686) (C) 2000-2015 MPlayer Team
FFmpeg version: N-72351-g1b23654
Build date: 2015-05-26 00:11:51 EDT
Setting process priority: abovenormal
Scanning dir C:/Program Files/SMPlayer/open-fonts
Playing rtsp://192.168.1.10:554.
Connecting to server 192.168.1.10[192.168.1.10]: 554...
rtsp: read error.
iBoston
2,607
2,156
North Central
sat2ip work fine :D
rtsp: read error.
Anyone else one chime in? Is Sat2IP starting SMplayer? Not sure i understand what is not working... What do you mean by 'Only lose my time'
Dodokoce
Jun 10, 2015
2
Rijeka
Somehow works on Alma s2210, though i cannot acess Encrypted channels that i watch on the stb itself. Also hd channels wont launch.. Is that a program's fault or is it stb?
iBoston
2,607
2,156
North Central
Never had any issues with HD channels. I made some modification to try and make it work with encrypted channels, but didn't have luck. It is difficult for me, as i cannot setup a test environment as I have no access to pay tv (encrypted) channels. In North America, Its all FTA here or nothing.
Dodokoce
Jun 10, 2015
2
Rijeka
Here in Europe most of the good channels are Encrypted, and i have acess to them on the box. But no problem, i like this program and it serves good if you want to watch some fta sports channels. Also quality is good, only probleim i occured is if you change the language stream starts lagging. But if there is an update to allow encrypted channels i will be happy to test it :)
FaT Air
HOA Free Zone
Feb 27, 2010
6,668
916
97W 48N
if I understand it right. The receiver streams the TP. Not the (decryped) audio/video. So I kinda think that may be impossible. Whatever you're viewing with would have to do the decryption. (But what do I know for sure????)
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
26,918
7,273
EM75xb
Yep Ding Ding Ding we have a winner!! :)
sc208
Mar 21, 2010
10
9
Connecticut
Unable to download.The link given no longer works. I have used this and it works great. I had a computer issue and lost it.Trying to reinstall the program.Any ideas of where it can be downloaded?
FTA4PA
Satellite Guys Family
7,622
5,952
Central Pennsylvania
I have a copy of it here on one of my drives. I will look and upload it. :)
Reactions: KE4EST
FTA4PA
7,622
5,952
OK, found it. Not sure, but I believe this was the latest one released by iBoston (v1.3.35 with sleep function and dish moving indicator).
  • Sat2IP_Install v1.3.35 with Sleep and Dish Moving Indicator.zip
Reactions: iBoston and KE4EST
sc208
Mar 21, 2010
10
9
Connecticut
Awesome!! Thanks FTA4PA!!! Reinstalled it and its working fine. Getting ready for football season ans hopefully will watch the CBS 4:22 feeds on Galaxy 28.
Reactions: FTA4PA
muscall
Aug 9, 2015
20
22
Trumann, AR
Sat2ip is an awesome program. It is working well here on windows 7 64bit. Planning on using it to feed a room with no cabling for the TV until the weather cools to the point I can get into the attic.
Thanks.
Reactions: iBoston
happyEg
Dec 17, 2015
5
Austria
Error in source: Typemismatch 64Bit
in Function Private Sub STARTPLAYER()
Wrong:
ElseIf FileExist(w32 + SMplayer) And FileExist(w32 And Mplayer) Then
Correct:
ElseIf FileExist(w32 + SMplayer) And FileExist(w32 + Mplayer) Then
What mean this message:
C:/Program Files (x86)/SMPlayer/mplayer/mplayer.exe -noquiet -slave -identify -nofs -sub-fuzziness 1 -vo direct3d, -ao dsound -priority abovenormal -nodr -double -nomouseinput -nokeepaspect -wid 4588672 -monitorpixelaspect 1 -subfont-osd-scale 3 -ass -embeddedfonts -ass-line-spacing 0 -ass-font-scale 1 -noflip-hebrew -ass-styles C:/Users/woody/.smplayer/styles.ass -subcp ISO-8859-1 -subpos 100 -volume 50 -cache 2048 -osdlevel 0 -prefer-ipv4 -vf-add screenshot -noslices -channels 2 -af-add scaletempo -af-add equalizer=0:0:0:0:0:0:0:0:0:0 -demuxer +lavf -nocorrect-pts -mc 1 -demuxer
Error parsing option on the command line: -demuxer
MPlayer Redxii-SVN-r37448-4.9.3 (i686) (C) 2000-2015 MPlayer Team
FFmpeg version: N-74447-g767d780
Build date: 2015-08-16 00:39:29 EDT
ID_EXIT=NONE
iBoston
2,607
2,156
North Central
Wrong:
Correct:
ID_EXIT=NONE
It sounds like your version of Mplayer has changed things. You can play with the command line call that calls mplayer.exe to get it working again. If i remember correctly, you should be able to remove the -demuxer and everything after it, as this is declared within the program regardless.
