The End Of The 922
Mike
117
16
Got a phone call today and they said they are basically shutting down all the 922 receivers at the end of April. (I assume they want them all back to be crushed and then dumped somewhere in the Nevada desert.)
They offered (in exchange for an owned 922 with OTA tuner) a rented Hopper w/Sling for free but it would cost $95 for a tech visit although I got that talked down to $50.
This is the main question here: I asked if the Hopper supports having a TV1/TV2 type arrangement (where TV2 can watch something else in standard definition, the "Home Distribution" ). She said yes. But there is no home distribution coax port on the back of a Hopper.
They also offered a 722 (I assume 722k). And then they'd have to include a Sling adapter thing for it to be equivalent.
I wonder if the 922 is being shut down because you can get unencrypted Sling video off it.
I'm considering just throwing all this equipment into a river and going OTA only with my TiVo Series 3 (that still gets updates unlike older Dish crap).
Reactions: pattykay
Nothing to do with Sling They are trying to move users up to HWS or H3.
If you do not own, or plan to own a second HDTV, then I would suggest the 722K with the sling adapter. It would cost you the same in receiver fees. And a tech visit would not be necessary. However, the Hopper w/Slings are terrific receivers!
While what she said was technically correct, like you discovered, it does not work the same way with the Hopper system as it did with the old ViP TV1/TV2 setup. With a Hopper, you will have to have a "Joey" receiver at each additional viewing location, up to three Joeys per Hopper (or 6 with a Hopper 3). The benefit is that they will be in HD (if you have/want an HDTV in the additional locations) and you can view all recordings on the Hopper from each Joey; however, the downside is that each Joey carries an add'l monthly receiver fee.
Not thrilled at replacing owned with leased.
I own my 722k also, but since they still charge you the EXACT same fees whether it's leased OR owned, there's only one advantage now to owning your receiver. The only advantage left to owning, is that you wouldn't have to sign any sort of contract for 2 years or whatever it is. However, most people would keep the system longer than that, and you'd then be off contract anyway...
But by renting, no out of pocket...and if one were to buy and keep beyond contract, then try to sell...MIGHT recoup half the investment.
Reactions: pattykay
Crap?? There are many here who feel the VIP series is still after all these years better than what some cable uses. My 612's are great and just about trouble free. What kind of updates would you feel they should be getting that the memory and processor could handle?
And it is my understanding TIVO series 3 can no longer be activated, if not already active.
Reactions: dishdude
[QUOTE="Tampa8, post: 3865016, member: 211"
And it is my understanding TIVO series 3 can no longer be activated, if not already active.[/QUOTE]
I kinda doubt that but when i call tivo will ask.
if you already own the box without service, tivo makes ZERO MONEY.
once activated the get income.
Did they ever get the 922 bugs worked out? I got rid of mine back in 2012, couldn't deal with it any more.
YES they did , that is why they are now ending the receiver and trashing it. I kept my 922 for less than a year and traded it back in for a 722k that worked. Hated that damn 922 receiver. Almost as much as my malfunctioning web tv dishplayer 7100/7200 models from 99. I don't remember how many of those I went through before I got my first 501 pvr that at least mostly worked.
Reactions: pattykay
UPDATE: I contacted DIRT and they are gonna look into this more. Could be maybe phone reps just wanting to generally sell/upgrade crap and that the 922 is not being systematically eliminated.
Do not want a contract. Any attempt to contract is an instant deal killer. It's such a PITA when you have a lease on an apartment and contracts for services and they don't line up. You move and then they get you for longer, etc. Big PITA. It'll be different when I buy a house but that's a few years down the line.
Also, needing (or more specifically having to pay for) a pro install for the HWS seemed to be the actual cost. The dish is literally about 10 feet away from the receiver, the signal comes in on a flat cable through the front door. Manager signed off on my install, it's grounded to the best of my understanding of those requirements. I've got all the coax tools, a spool of wire and I can go buy another flat cable if that's what the install really is. Or if it's because the Joeys use Ethernet, this apartment is wired for Ethernet in all the rooms, as well as Coax isolated from the cable TV network.
She actually made it sound like the Hopper base unit had TV1/TV2, but if I wanted any more than that, then I would need Joeys. That sounds really wrong so I didn't go through with any deal.
I live alone but I have a guest room in the apartment, family or friends will stay over. I can change the 922 over to Duo mode, bam, my guest room has it's own TV now. No extra fees. I'll pay for programming, that's fair (relatively). Not for extra boxes to sit unused most of the time. Bedroom does not need HD
There still remains a bug where on every 4th or so daily reboot, the little PIP picture in the guide will be rendered in the bottom left corner instead of the top left corner. Literally this bug has been there ever since I became a customer, I have exchanged the 922 a few times for other reasons. I know there's been one or two software updates since then. This cannot be that difficult of a bug to fix! I don't think you need to double the memory just to draw the video in the right place since it does get it right most of the time! Tons of little bugs like this, I've reported, they are just never fixed. The primary functionality does generally work (it records stuff, and you can typically watch the recordings).
I agree that E* equipment is infinitely better than the cable crap (which is why I always used TiVo on cable). However I have not used the X1 so I can't speak as to that system.
I have a lifetime S3 (I understand not activating S1 or S2 but on the TiVo forums we couldn't really figure out why they would stop activating newer S3's). They just added MPEG-4 support for Comcast to the later model S3's. They have a decoder chip, it was just never used until now.
One last thing. Lately the on demand selection of the 922 has sucked rocks. I have HBO (some kind of deal where it's $10 a month) and there's just nothing there. Couple of random episodes of weird stuff and a few movies. There's no filters on or anything.
I finally get this awesome 100 Mbit connection through the apartment and go to check out on demand and it's barren. Maybe related somehow?
Reactions: pattykay
Yea for the most part.....I still have one at the X's house, it still streams great....
After going through 4 in a year, its been solid since 2012...
I would decline all offers as I assume there have been no other posts regarding the 922's being eliminated. Unless more fees is something you want. Sure the hopper is a better device, but having to shell out 50 bucks and a increased monthly rate to replace what you currently are happy with seems wrong, especially if they want your owned 922 back.
Worst case I would take the 722k.
once activated the get income.[/QUOTE]
It is True. A lot has changed including the new "All-in" is now $599 and TiVO no longer, repeat, NO longer offers Multi-service Discount. TiVo will NOT activate a previously inactive S3 (includes the HD and HDXL) nor will they transfer "ownership" to accounts of older TiVo units even if active butwith monthly plans. Only S3's with Lifetime can be transferred to accounts such as those purchased from 3rd parties or from individuals. It will take a phone call to acheive this. TiVo has been firm and unwavering on this. It is their clear business decision. They want everyone to buy a Bolt, and they are desperate.
Also, many features of the S3 have been taken away or one could say TiVo has neutered the S3's of nearly all its most compelling features beyond being a simple DVR. The only feature left is access to Netflix, and that is not so great. On the other hand S3's have lost YouTube, Amazon, TiVo search accross all services for contenet such as Netflix, and we lost all the other apps (except Netflix). The S3's no longer have ANY on-line functions/features or access, and MORE things taken away from the S3 by TiVo . Many with S3's are understandably upset over this. It aint goona be the S3 you had when you put it away. If your S3 it aint PLS, then you are SOL.
Also, are you aware that Rovi is in talks with TiVo to merge the two companies? This is taken as bad news by most as Rovi has a record of abondoning users of its service and is NOT a hardware or retail company--AND TiVo made it clear that everything is riding on the Bolt for it to continue its retail part of the business. Many feel that if Rovi does buy TiVo it could mean the end of TiVo as a hardware DVR retailer. Get yourself up to speed at the TCF and do read the sticky thread of Q & A from TiVo's CMO Ira Bahr. It is an excellent resource. I and many others are pessimistic regarding Rovi and what they would do or NOT do with TiVo, but we will have to wait and see if the deal goes through and what the future for TiVo will be.
You may want to consider the Channel Master DVR+ for your OTA DVR recording needs.
Reactions: navychop and Tampa8
TIVO has always had customer unfriendly policies from time to time:(
example for awhile they refused to sell any new lifetime services.
then they went back to offering lifetimes.
frankly they have a wonderful product with excellent software. worlds ahead of dish when i dumped them over fees.....
tivos just tend to work.
myold line says it all. you shouldnt have to be a tech to watch tv.....
They have always offered lifetime. The Roamio OTA was the only exception of no lifetime on the unit unless you had purchased a unit that had lifetime on it (that started last May or so....). The previous monthly units they wouldnt allow it. So I upgraded to a Basic Roamio and they threw lifetime on it :)
(already had a S3 with Lifetime on it)
If they are getting rid of the 922 why can you still buy them from dish retailers?
Need help with Sling part of new Hopper 3
