Got new HR44 instead of HR54?
dmproske
May 25, 2016
3
SE Texas
I've been a DTV customer since 2005, have had the protection plan as far back as I can remember. So I called to upgrade my HR24 to a Genie. Since their website says I could upgrade to the "Latest Technology" from DTV I asked over the phone which DVR I would be getting, since the HR54 is the most current. They said most likely a 54.
So today the tech comes out to do the install while I was at work. He installed a HR44. She asked why not a HR54. He said he did not have a HR54 to install, and that "HR54 IS FOR 4K SYSTEMS ONLY". I am throwing the BS flag on that. Also doesn't seem right to me that when using the upgrade on my protection plan that I am paying extra for, that I would not receive the latest equipment. I understand when replacing broken equipment you receive whatever is available, but I thought upgrading was different.
I am going to call them, but wanted to get educated here first. HR54 only for 4K??? Is that correct? If not should I have received a 54?
Thank you for the help.
This isn't BS. It is true, HR54's are only installed on 4K true work orders which means to be promised a 54 you would have to be getting 4K content.
I'd go on to say that, as a SWAG, you'll be upgrading equipment in 3-5 years for whatever 4K actually turns out to be in terms of receiving equipment.
Really, DirecTV is so bleeding edge here that even the HR54 can only handle a channel of 4K viewing at a time.
Just my $0.02.
If ya don't have a 4K set (sounds like you don't) I wouldn't be too concerned about it, the HR44 is a very good reliable unit.
Now question I have, would be, say in 3-6 months he goes out and gets a 4K and wants his 4k signal.
He would have to call and upgrade again to a 54/61 ...
Does he have to pay addl. for these, seeing he'll probably (maybe) have to pay for the 44.
Is he stuck in a new 2 year commitment again ?
Yeah, that's the crappy part. He's stuck at this point and if he upgrades it'll cost him. We've been told of the work order is flagged 4K but doesn't have a 4K tv to remove the 4K client and add just a normal client.
Maybe, when time comes, he can talk to them and explain the situation and they can work with him.
Personally, I wouldn't want the 54 ... unless I'm just playing with it.
I would much rather wait and see whats next, will there be a true HR 64 maybe, that does 4k all in one box ?
Reactions: AZ. and mdram
That was my situation when I researched it before my install, and talked to a user here. I knew you had to have a 4K display to get an HR54, but I didn't want to deal with the client. I just decided to go HR44 + HR24 and wait for hopefully a 4K DVR.
Big thing you dont want is an HR34!
Reactions: Jimbo
Well I stand corrected. This is the 1st I have heard of this. Hopefully my current TV will last a few years before I need to upgrade. 4k will be more mainstream by then. Thanks for the information.
Sent from my SM-G935V using Tapatalk
IIRC, some have lucked up and gotten an HR54 because that is all the installer had (on a standard Genie install), but only way to ensure you got it over a 34/44 was a 4K note on your work order.
I made sure when the guy got here he had an HR44, because I was going to refuse the HR34.
You should not be upset sir, the HR-44 is great and the 54 is the same just 4k compatible and then you have to have a c61k mini to make it work. I honestly would rather have the 44 over the 54 because I am not chasing the dragon on this 4k crap. You will be very happy with the 44, good luck.
I got the 54 and it was not a specific 4K install although I do have a 4K tv I got c51 minis too - he had both a 44 and 54 on the truck the other diff is the power or something else is built in vs on the outside - everything is working great happy so far
the HR54's, while flagged for 4k jobs, still gather time on them. if you have a 54 without 4k, it was probably one the tech had to unload to avoid having to pay D* back. kinda stupid really.
Reactions: Hutch1814
