Found this dish, as identified in the C-Band forum:
Kijiji, eBay, and Craigslist dishes for you to take a look at
Picked it up late last night by just putting if on the trailer and hauling it ~130 miles home completely assembled, which was probably a mistake. I rationed that the 60-80 mph wind blowing across the reflector wouldn't hurt anything. I didn't think of the mass and lever arm of the Rx/Tx assembly pulling on the feed support and stabilizer arms, which lead to the feed support mount at the dish breaking long with one of the side support arm mount holes in the dish. Oh well, live and learn...
First thing to do was to cut down the NPRM so it's only about 4'x4' instead of 6.5'x6.5'. I don't kneed the size for stability, just a base to hold the dish for some testing. Here's the dish peeking out of the back shop door with the smaller base.
This is the Tx/Rx with the feed for the reflector. My goal was to reuse the rectangular feed horn with an Eagle Aspen 270 Ku LNB. This was pretty simple to do. Only the feedhorn mounting holes needed to be elongated to let them mate up. Here's also the new LNB and old feedhorn temporarily tied to the feed arm in the proper position.
The mount is a EL/AZ with Skew. All aiming axis have scales that are fairly accurate.
97w was easily acquired, along with 87w, 103w and 125w. The scales are by far the best of any dish I've used. Just swing them around to the numbers you need and the sat is right there. Nice!
I used the RT and NHK transponder off 103 to jusge performance. I was easily able to get 15.8 to 16.0 c/n on the SH200 meter on 11940 V 20000. Not sure how that compares to my other dishes, I'll note c/n for the various dishes when I get to getting them put in service.
The reflector is 23.5" wide by 53" wide.
A couple last photos, one with a Primestar 84e reflector laid on for comparison. If anyone has an idea of what this is, please inform! I've looked at Prodeline Hughes Earth stations and cannot find anything. I did find the TX/Rx assembly, but that wasn't that much help, and n ow I can't "re-find" it again.
