OTHER Basic DVB-S/S2 Receiver
Radioguy41
2,809
2,813
Lehighton, PA
Just a couple things to note that may not be obvious to anyone reading this thread.
First, it appears that there are two different models of this device that are both called the Freesat V7. One does not have any built-in network connectivity and the other has built-in wifi. Here are example of the two from AliExpress (I am not suggesting you buy from there, just pointing out the difference):
http://www.aliexpress.com/item/MINI...set-top-box-support-biss-key/32547085308.html
http://www.aliexpress.com/store/pro...-S2-Support-Ccam-IPTV/926289_32548835961.html
If you compare the specs they are the exact same unit, both support Wi-Fi.
ancient
420
217
USA
Then the tuner that doesn't tune the 16APSK is a tuner that doesn't have the capability to tune 16APSK? Makes sense! LOL :D
True, but it was sold as being able to do 16APSK, and therefore I thought it did until I very recently found out otherwise.
Well if that is true (and I'm not saying it isn't) then why does the description for the first one include this?
Dear friend,pls note the v7 no have lan port
if you want to have it work [removed mention of software used for piracy]
pls buy wifi version​
And then it gives the link to the other one. So the seller seems to think there are two different versions, although then again, he mentions a "lan port" and from the photos I've seen, no version of that receiver has that, assuming we are talking about an ethernet jack. Maybe the seller is confused; I don't know, but I just thought it worth pointing out that if having the wifi is important, make sure it's mentioned in the specs of the one you buy because there just might be a version that doesn't have it (or not).
Radioguy41
2,809
2,813
Lehighton, PA
The specs are identical and both list Wi-Fi. LAN is a different animal from Wi-Fi. LAN is wired, Wi-Fi is wireless. Neither unit has a Cat5 port.
ancient
420
217
USA
So, either that seller doesn't know his own product or he's intentionally trying to confuse people, and if the latter, it worked with me. :confused:
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
26,925
7,276
EM75xb
I'd say he has no idea what he is talking about, just trying to ride the next train to a quick buck.
Babadem
2,301
166
MA
Probably he was referring to the Wifi dongle!
mr3p
1,308
257
West
I checked out the links above and both appear to be the same receiver but one includes a USB Wifi adapter as shown in the picture. Have a look at the Freesat website for a list of their models
beavs2112
Addicted to Legal FTA
Jan 28, 2010
814
248
London Ontario Canada
waylew
2,920
1,222
northern WEST new york
Got mine this afternoon,just a cursory playing with it so far.Two sats scanned in,101&105,easy enough.Missed MeTV SD on blind scan but HD was there,noted an audio sync problem there.H&I,Decades and Movies scanned in and playing.
On 105 NBCs/Cozi etc are in,DMX on the radio side playing fine.
Tried deleting some channels but wouldn't do it,at this point probably user error :biggrin.
Checked the WIFI and it said No Such something or other,I don't remember exactly.
Clock seems to be 24 hour only,but again may just be me not doing something right yet.
Need to get a composite breakout cable,think I have one around somewhere,whether it works or not to be determined.
But so far HD looks great and SD looked pretty good on the Bravia.
ancient
420
217
USA
ancient TBS has a more reasonably priced dual tuner card here http://www.buydvb.net/tbs6902-dvbs2-dual-tuner-pcie-card-p-135.html?cPath=2 that says it will do up to 32APSK. Might be worth checking into.
I appreciate the suggestion but at this point I really don't trust the claimed specifications from TBS anymore, after all they said my card would do 16APSK back when they were selling it. Now if someone is currently using a reasonably priced (in other words, not "professional" grade) TBS card and is actually receiving that 16APSK mux, I'd like to know what model card you have. But, I won't make the mistake of relying on TBS' claimed specs again.
Titanium
AI6US
7,650
9,065
Meadow Vista, Northern California
TBS is a very customer oriented company and have been very responsive to my support needs on several occasions. Why don't you contact them and indicate that you purchased the card based on the specifications and ask if they would swap for a comparable card with 16APSK support. All they can say is no...
ancient
420
217
USA
Thanks for the suggestion. Did that and unfortunately the response I got was not completely helpful, but only because my TVHeadEnd backend system is running Ubuntu Server, not a version of Ubuntu with a desktop and definitely not Windows (I don't think there even is a Windows version of TVHeadEnd). And also, I don't really understand what they are asking. They said, "We need to make sure what kind of signa with 3980H first, is it ACM or VCM ?" And I don't know what signa is or what ACM and VCM are. But then they asked me to use crazyscan with my existing tuner card analyze the frequency, and they gave me THREE links as follows, but none of them are to a Linux version of the software as far as I can tell:
They also included a sample a screenshot of what they want to see, which I can only assume is output of one of those programs. I am not sure which, but it appears to have a graph in the upper left corner with four red circles surrounded by blue rims with blue dots, I assume it's graphing something but I have no idea what, and most of the other information in the screenshot was meaningless to me aside from obvious things such as frequency, symbol rate, modulation, FEC, etc. Maybe some readers of this thread would know exactly what that is, but I don't. EDIT: It looks very similar to this one, except all the text is in English.
It sounded like they might be willing to do something for me, but only after receiving this information. I don't know if they are trying to discover something specific about my card, or if they are trying to figure out if a different card would be able to receive this signal. The obvious problem is I have no way to run the software they want me to run, first because there is no Windows on that system, and second because there is no graphical environment. So even if there were a similar program for Ubuntu desktop versions, I probably couldn't run it. And then there is the obvious question, if my 6985 won't receive 16APSK in the first place, how would I get any information in crazyscan even if I were running Windows?
If anyone reading this has a TBS card is running crazyscan and could run it on the 3980H mux on G19 and post a screenshot of the output, I'd very much appreciate that, because if they are just looking for information about the signal then that should give them what they need. But if they are wanting information about my specific card, unfortunately I just can't provide that using the software they want me to run.
TheBUDGuy
169
64
Lexington, KY
I'm getting aggravated that I'm not getting Decades, Heroes, & Movies! anymore on SES 1; because of that, I'm thinking about ordering this receiver. From what I've heard, it performs great on these 3 channels without any problems; by the way, I could care less about its "supposed" ability to unencrypt BISS, PowerVu, or any encryption software with keys; I'm not up for anything like that! :biggrin I could also care less about the other useless extras such as YouTube and especially YouPorn! :biggrin Anyway, I was wondering if this STB decodes 32APSK modulation?
Reactions: fred555
OTHER Universal LNB - Linear - on a DISH NET 1000.2 dish
Setting for ANIK F2 Fortec 90
