HR54 not working but clients are working
curtishd
181
I have a HR54 that is not working but I have two clients C61K's that are working. I did a hard reset with the red button as well as unplug the HR54 but the HR54 still displays nothing on the screen when I select a channel and the guide does not fully load. Any ideas what's wrong?
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,807
17,753
Cheshire CT
Sounds like you should be calling customer service. Have you checked all of your connections?
Jimbo
Cutting Edge
Jul 14, 2005
68,924
7,274
NW Ohio - Buckeye Country
First thing I thought of was a bad connection, then he said guide didn't load all the way ...
Which meant he could see the guide, which meant his HDMI was probably OK.
Not sure how the clients could work if the Genie itself was not.
Bascott97
85
6
Arkansas
Force a software update. Press reset on the 54, when the Directv logo lights up press 0,2,4,6,8. Then wait. It should show the update downloading on the screen.
curtishd
181
I'll give the software update a try. I thought it was weird that the clients were working but not the genie.
b52pooh
93
9
Oregon
More information about what you are seeing on the screen would be helpful. When you say the guide doesn't load completely, what do you mean? The guide info only goes out one day? You only see an outline of the guide? The channel numbers are missing? There are no programs listed? Do you see any error messages on the screen when you select a channel? is the problem on all channels? Or just one or two? The more info we have, the easier it is to pinpoint your problem.
Aridon
546
47
Simple stuff first. The reboot is great (including the swm), that would be my first attempt to fix it. Then changing the HDMI cords. Then the software update force. Then call D*
curtishd
181
I did another reset and it's working right but I also have a service call this week so I will keep it and have them check all the connections just in case. My other DVR hr24 was also have issues and freezing too so I think the issues would be in the lines closer to the dish.
Jimbo
Cutting Edge
Jul 14, 2005
68,924
7,274
If both recvrs are having the same issues, it could be a multiswitch or the LNB.
Or bad connectors on the coax, but thats not as likely seeing its multiple recvrs, unless both are connected outside.
Schedule fine Wednesday now showing wrong start times
Genie DVR Question
