Answer depends on 1) What Dish/LNB you are using (how many connectors on LNB, SWM??), 2) What wiring inside RV is already in place ( the connection from outside is one wire , splitters ? etc) and 3) what are you willing to do to run wire (Coax, HDMI) inside RV?
Doctor j
Ok,
I'm a different person with similar issue and more specific info.
My brother has D* (I have E*).
He has an rv mounted VuQube.
LNB has 1 connector.
Single 1-foot rg6 to 'regular old cable splitter'.
Rg6 to each of 2 D* recievers (D12-100).
He is able to get each of the D12s to get signal and tuner different channels.
Ocassionally, one or the other of the D12s will lose signal.
He purchased an EagleAspen DTV3x4 minimax multiswitch.
We cannot find an installation diagram for connecting 1-connector lnb to the multiswitch.
Multiswitch has 2-SAT inputs (1-18VSAT, 1-13VSAT).
Will this switch only work with 2 lnb connectors?
Will it work with splittering the single lnb connector to each of the multiswitch inputs?
Sent from my GT-P5113 using the
SatelliteGuys app!
