Well, this problem was initially mentioned in the other thread I started, but, it's worse now with the Micro HD than before, hence the new thread for the Micro HD.
As I mentioned in the other thread, the Micro HD in question here in my shop initially had problems with multiple recordings but did work fine on a single. Then yesterday it started not working at all with the timer so this morning I copied the files off the working one in the house and loaded ALL of them into this one here in the shop and it's still horked up?? I can make it record via the record button on the remote but it WILL NOT start the recording via the timer at all.
So after that I found the latest firmware I have and loaded that then went in and setup ONE satellite (97w) to try the record timer before I installed any others and the timer record FAILED that way also, and yes, I did the factory reset after the firmware install BEFORE I did anything to install 97W to test with. After it failed to start recording I went in and looked at the timer setting menu and there was nothing there, meaning that it had tried to initiate the record function but didn't record.
I might mention here that I've been having "some" problems with this Micro HD moving the dish reliably for some time, ie, over the last year or so about half the time I've been having to move the dish via the Vbox remote instead? Going into the TP menu and moving up and down that list seemed to make it work OK but not when I just went from one sat to another in normal TV watching mode.
So now I'm looking for suggestions on fixing this problem?
Forgot To Add: Yes, I did switch Vbox Controllers testing the dish move problem and it does the same thing with BOTH of them.
