USB Charger Causing Radio Interference -RFI
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
My USB wall outlets interfere with my hd table radio., just the ones next to the radio.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
It takes some pretty serious noise (or a not fantastic radio) to interfere with FM. Are you hearing the interference on AM, FM or HD?
I haven't checked the AM or FM, but it definitely interferes with the HD signals.
harshness
18,889
4,063
Salem, OR
If it is interfering with the Hybrid Digital signal, that's probably a defect/fault of the radio itself. Digital decoders typically can't decode a signal that has been interfered with so I'm suspicious that the interference is coming in after the decode section.
Of course if a quality AC adapter addresses the problem with the radio, everybody's happy.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
Like I mentioned, I'm using a wall USB outlet. The radio is a Sangean, supposedly a good one.
Titanium
AI6US
7,650
9,065
Meadow Vista, Northern California
Doesn't matter if the radio is cheap, expensive or well constructed. If a device is generating a signal, a tuner will receive it. A quality radio may have better rejection and/or shielding, but every receiver needs an antenna.
Viewing the radiated broadband noise from various chargers with a scope, the RF garbage is generated across broad swaths of frequencies. Tuning HF/VHF/UHF frequencies with a Yaesu FT-991, LMR400 feedline and external antennas 100' away, several wall and 12VDC USB chargers are received in analog and digital modes with sufficient strength to prevent reception of stations that are easily copied when the charger is unplugged.
It's all about Signal to Noise Ratios... if the charger presents a signal that competes with off air signals, radio reception will be affected.
Reactions: KE4EST
harshness
18,889
4,063
Salem, OR
But in this case, the signal being stomped on is digital and that's not something that gets interfered on as readily and if it does, it is most likely going to be considerably trashed, not just interfered with.
Titanium
AI6US
7,650
9,065
I have experienced digital radio interference first hand... Interference affects both digital and analog signals. Yes, the digital cliff is often a hard cut, but I often hear digital radio signals get choppy, chips, tone blasts, etc... all effects of poor signal to noise ratio causing decoding issues.
Yes, raoul5788, the wall wart is likely causing interference with your digital radio. Chargers, controllers, power supplies, ballasts, (insert any device capable of radiating wanted or unwanted signals), etc. cause reception interference in both the analog and the digital worlds.
Reactions: raoul5788
harshness
18,889
4,063
Salem, OR
Sangean makes excellent equipment and as the link I provided earlier witnesses, their new wall warts (such as the one used on the HDR-18) are remarkable.
When you say "wall USB outlet" is this a wall wart with an A jack or an electrical duplex outlet that has USB charging ports built in similar to the one pictured below?
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
I've had the radio nearly ten years. It's the HDR-1.
Maybe it's time to upgrade.
Titanium
AI6US
7,650
9,065
Shouldn't need to buy a new radio to address interference, but that may be a simple option if the source can't be addressed. The HDR-1 has limited options as it has an internal power supply and limited antenna relocation options.
Is the HDR-1 plugged into this outlet or same breaker? Does the interference go away if the HDR-1 is plugged into a different outlet on different breaker? If not, will the interference go away if the USB outlet breaker is turned off? Does the proximity of the HDR-1 to the USB outlet affect the amount of interference? These tests would point to the way the USB outlet interfering signal is being distributed and possibly provide ideas on how to attenuate or eliminate. Is it interfering via the electrical connection or over the air?
If the USB outlet is back feeding the breaker box, then your entire electrical system becomes an antenna to radiate the I interfering signal. If so, it might be possible to isolate the USB outlet from the breaker or even use ferrites on the AC distribution runs to the outlet and minimize the interference. If I discovered the hardwired USB outlet was backfeeding the interference into the electrical system or radiating from the device, I would contact the company for a solution. It's not like it's a portable charger that can be moved/removed as needed.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
I'm using the same outlet for the radio and for charging. I haven't tried a different one for the radio or anything else you suggested except unplugging the data cable does bring back the radio reception.
Reactions: Titanium
harshness
18,889
4,063
Salem, OR
Unplugging the USB cable turns off the 5V power supply in the outlet so that definitely pinpoints the outlet as the source of the interference.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
Yes, but what happens if I use a different outlet, particularly one on the other leg of the service?
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
Turns out it had nothing to do with interference from the wall outlet. I had a bad connector at the antenna! All is well, thanks for all the advice.
Reactions: Titanium
