Stuck with this TV as it fits into the space (it's 28" tv) well.How about trying a different tv? Is that possible?
Is this D* service going thru any boxes that came with the camper/ RV ?
Thanks for the break down, now I have a better idea what your doing ...Jimbo, the destination travel trailer has 2 satellite in connections on the outside. I have the 2 connection splitter right out there. Inside, each Directv box is connected with a short coax to 1 of the 2 cable outputs embedded in the camper at each tv location (main room and bedroom), The other coax connection, which comes in from the HD antenna on top of the unit goes directly to the TV. The Hisense TV that came with the camper (and is at the main location) is working fine, while my Hannspree tv in the bedroom is having this issue. I had an SD box in the bedroom b/4, but now have the H24-200 box and it works well ONCE I re-select an input source each time I power it on and it says "no signal" via the HDMI1 it is now set to. Again, I have to use the TV controller to select any other input source, whether an actual connection or not, and then re-select the HdMI1 - and then the DIrectv signal comes right up. I believe all the wiring and internal camper connections are working fine. I think it may be an issue within the TV, AND I was wondering why the DIrectv remote will not LET me select a CHANGE in the input source when the TV Input button is clicked - even tho it does DISPLAY all of the Input Sources available.
Walmart has them for like $10-$20.
If your thinking Rat Shack, try $40. Although I miss the place, they ran themselves out of business selling over priced accessories.
As I am troubleshooting this 2nd replacement HD which I just received, I find that this no signal issue may actually have something to do with the Hannspree TV? I have a coax connected from the camper antenna connected directly to the TV, I have an HDMI from the TV to the DirecTV HD box. When I turn on the TV which is set to HDMI input, I get the NO signal. If I switch to the TV input, I get a picture from the camper antenna. THEN, if I switch BACK to the HDMI input, IT WORKS!
It could be ...Jimbo., I did the auto setup of the remote (and I also tried the RF remote from the other main TV which had the same tv input display shown but the "no change" of tv input issue). Each remote works fine with the on/off, and volume, etc., just that the TV input displays BUT cannot select a different source. Thank you much! I might try all the different codes to see if that might correct it, but could it just be something in the TV itself? I have emailed Hannspree support hoping to get some response ...
