Subchannel Discussion Thread
Also KAJF-LD and KCMN have been downgraded meaning channel numbers know in 4 digits.
Why would four digits be required? Do you really mean that they're going to a CC-ss configuration because they're contemplating 10 or more streams? I'm pretty sure no DTV tuner can handle channels >81 (in AIR mode, obviously).
How is that a downgrade (aside from the obvious abandonment of PQ and AQ)?
After all the going on and on about adding channels, you can't righteously complain about the result now.
If you look at the Bounce website it says Bounce will soon be available on Dish.
Because it is "coming soon" to markets that don't currently have affiliates, I'm going out on a limb and guess that if it happens, it will be a CONUS offering for DISH as opposed to a LIL configuration. I'm betting the broadcasters are not liking this kind of activity (only a half dozen of the 145 affiliates are Scripps O&O).
I don't imagine Bounce has any locally produced content at the affiliate level but I'm pretty sure there's locally inserted ads in their Afro-American focused programming.
RabbitEars.Info Both are in Topeka and none of the full power in KC area have 4 digits only on Cable Systems and other low power none yet.
So the subchannel numbering starts at 1001. That's asinine.
I still don't understand how it is a "downgrade" other than being a slippery slope (get it -- down grade) into incompatibility with many tuners. I'm going to have to dig into the PSIP guidelines.
Cable systems can renumber channels any way they want. Our local Suddenlink has many such channels. Not a big deal.
My original assumption was that the channel number could be four digits and that's not something my QAM capable TV supports. Now that Mgsports has clarified what he said, it turns out to be something that my TV may not support but it is actually OTA related and the cable TV reference was a red herring.
Mediacom,Comcast KC area have Duplicate channels of local channels in HD same with Digital Sub channels on Mediacom but one shows QAM Channel number that other providers won't show in their Lineup Online. The difference is a Cable provider like CCI on TV's without a Box gets like Music Choice that can be picked same with some National channels past 99. It's up to like Broadcasting groups wanting to add some of those channels that KAJF-LD and KCMN have.
Fortunately for this sub-forum, we don't have to worry about what Mediacom, CCI or Charter are doing.
We definitely need to be concerned with OTA subchannels starting at 1001 (as does cable TV).
The ATSC A/65 standard is where the PSIP parameters are defined and I found this appendix item (G.3.3)
ATSC A/65 said:
For minor channel numbers, this Standard specifies that zero shall be used for NTSC analog
television services, 1 to 99 for ATSC digital television or audio only services, or 1 to 999 for data
services. Minor channel numbers for cable, on the other hand, have no restrictions on use: they
can range from 0 to 999 for any type of service.
So the maximum minor channel number is 99 for OTA and 999 for cable TV.
Those 2 are low power stations and are from Topeka but can be picked up in KC area and has some good channels like GETTV,Country Network,Quest,Decades,Movies,H and I,Stadium.
Another thing about Cable Systems they tend to not want to add low power stations other then one in northeast MO that picks up KCKS-LD channels and QAM channels on Cable Systems Digital Sub channels are the same ones your Cable System has so just because on Antenna in KC Area like Comet TV,Light TV,Escape,This TV,TBN,Life,Qubo,IONSHOP because CCI doesn't have them yet on QAM for CCI won't show up.
Again with the cable TV distraction?
Cable doesn't want to carry these channels because they might, at first glance, seem to compete with pay TV options. Those with cable typically have established channels as well as OTT options available for much of the same content. There isn't a lot of exclusive content on subchannels.
There is no must-carry for these channels as there's seldom any local programming on them (other than commercials). The return on bandwidth investment just doesn't look very good.
Bounce has picked up the rights to air Scandal starting next Monday. Fairly big acquisition for a diginet with it being such a recent show ‘Scandal’ Rights To Bounce, Will Get Nightly Runs Starting Monday
There's precious little high quality Afro-centric programing to acquire so it makes a lot of sense for Bounce to pounce on Scandal. A lot of the competitive content is from premium channels and streaming services isn't really suitable for OTA broadcast without serious butchering.
It is a shame that it will probably be broadcast mostly on SD subchannels.
Reactions: osu1991
WVIA moving frequencies on 7/15/19 at 10:00am
Article: Charter doubtful about the future of ATSC 3.0
