Houston Tracker III Plus
elcheca1
Oct 4, 2017
24
2
Dominican Republic
Hi, I have a little problem with my Tracker Locator, when I connect the engine and press the EAST / WEST buttons, it must turn left and right and it does not do anything, the Tracker turns on well but that little option I do not know how to solve it, if someone has passed this please comment please :sorrow:sorrow:sorrow:sorrow
Does the motor move with 12Vdc battery attached to M1/M2 wires?
If the motor moves with 12Vdc battery, place a continuity tester across the S1/S2 leads as the motor moves. Does the continuity meter show open/close cycles?
yes, I connect a 12v laptop battery and the actuator works, the problem is in the Tracker, I have not yet tried that of the continuity tester but you think that will help the tracker work?
