TNAP 3.2 Time Question
JFOK
1,073
804
Cape Cod - MA.
Hi All,
I'm in the process of setting up TNAP 3.2 on my stb.
Most of setup is going smoothly however, how do I set my local time ?
The closest I can get to my time zone here on Cape Cod, is London.
What am I missing ? Is there a plugin I have to download ?
Thanks in advance for any responses. Stay well.
John
SDA_FL_USA
304
295
FL
I don't see London on the list here. I know you flashed the emmc version and I flashed the multiboot version of TNAP 3.2 so maybe there is a difference. Might put the multiboot version in slot 2 and see.
Reactions: JFOK
JFOK
1,073
804
Cape Cod - MA.
Brian,
Thanks AGAIN for your assistance.
I’m really liking this TNAP 3.2.
Just updated and put in the proper time zone. I also installed a different skin (Blue Shadow FHD) as recommended by “el bandido.”
Thanks again and stay well.
John
Corrado
2,428
303
Hudson Valley Region, NY
I just upgraded to TNAP 3.2 and found the same issue with the time zones. Thanks for the resolution. I'm using the skin that closely resembles OpenPLi. Nice work that el bandido and his team did.
Reactions: JFOK
LocutusOfBorg
Free speech is more important than your feelings
13,557
7,724
USA
I had to manually install tzcode with opkg from the cli. Even after installing that, setting the TZ, and enabling time sync via NTP, my time is still occasionally incorrect on both my mio's. Usually it's correct but then I'll look at the display and the time is way off - not even the minutes are correct. Then the box will self correct - eventually. If I wanted to set a time to record a program I couldn't trust that the program will get recorded.
root@osmio4k-office:~# opkg list | grep timezone
tzcode, timezone zoneinfo utils -- zic, zdump, tzselect
primestar31
13,567
14,029
Beta Omicron Delta III
Is your Mio wired, or wireless, I can't remember? The only time mine goes way off, is IF I switch back and forth between slots, then it still occasionally jumps to like the year 2069. Mine is wired, BTW, and I'm still running the original TNAP. Settings like this: MIO_SystemTime_Settings_20190219172706.jpg
LocutusOfBorg
13,557
7,724
USA
Wired. My time settings are the same as yours except I changed my NTP server to us.pool.ntp.org
Reactions: primestar31
primestar31
13,567
14,029
I've seen my front screen clock sometimes drift off by a minute or two, not sure why, but it corrects itself. It hasn't done that for some time now, so not sure what was going on there. Maybe something with my Spectrum internet? Who knows.
As long as it doesn't do that year 2069 crap anymore, I don't think about it too hard, lol.
LocutusOfBorg
13,557
7,724
USA
Seriously - this box is Linux based and you get the time from Windows! There has got to be a better way! :D
He probably uses a Windows PC to connect to the Linux based mio with WebIF.......
FTA4PA
Satellite Guys Family
7,622
5,952
Central Pennsylvania
I had a linux machine that I spent more time working on than using it. A real mental exercise that I was not that interested in.
True, Linux does require more work than out of the box Windows but that's what I prefer - it is so customizeble. You can make it look and do exactly what you want. :)
JFOK
1,073
804
Cape Cod - MA.
Hi All,
Is there a way to change the clock reading from military to AM- PM ?
I don't see a way to change it specifically for the TNAP 3.2 image (Blue Shadow FHD) I'm using.
Thanks in advance.
John
JFOK
1,073
804
Cape Cod - MA.
Brian,
Thanks for your response.
I kinda figured that was the case, but just wanted to check.
None the less, I’m glad you convinced me to try TNAP 3.2.
Stay well
John
Reactions: Titanium
