HR24 Flashing Occasionally
Jimbo
Cutting Edge
Jul 14, 2005
68,888
7,244
NW Ohio - Buckeye Country
Hi Guys,
I need some info/ advice ...
I have a HR24 that is acting a bit weird ... the Power light, which typically flashes when the remote buttons are pressed .... is flashing when the remote is NOT being use ... I did confirm last night that it is not the actual remote.
Its of course slow, but seeing its an HR24 at this point we expect it to run a little slow.
Any one have any ideas as to what might be causing this ?
The recvr has worked fine, channel changing is slow, but you expect that.
Before anyone suggests a Client, that won't work as its the unit for the Motorhome, so I can't count on anything for a server.
Thanks for any thoughts / ideas .
I have already done the typical RBR, Clearmybox, most of the typical things.
Never heard of this, but it doesn't sound good. Maybe a fault code of some sort?
