Screensaver
lgb0250
368
318
Just got a new tv and when I use my harmony to turn everything off the DISH screensaver pops up and bounces around. The screensaver never popped up on my old tv using the same harmony. Just started on the new one I hooked up yesterday. H3 w/H306.
jwill
56
14
Your harmony isn't turning everything off, the TV is staying on. Make sure the harmony is set to turn off devices not being used.
jerryez
4,750
1,301
Pensacola,FL
I use My Harmony thru a Onkyo AV receiver. There is a setting in there to choose one of the inputs for pass-thru or turn pass-thru off. If you have an AV receiver, you might look at that setting. I have mine set to pass thru the HDMI cable that my Dish Hopper 3 is hooked to.
OR your new tv could have a screen saver. Check your tv settings also.
Did you reprogram your Harmony remote to the new tv. You have to delete the old tv and enter the new tv in the My Harmony app on you computer.
lgb0250
368
318
Followed all these suggestions. Unfortunately the new tv is not in 5he Harmony data base and has to be taught by pushing buttons. Obviously I’ve missed some. Will attack it again today. as Always, thanks for the input.
Reactions: Howard Simmons
lgb0250
368
318
Finally got it set up correctly. The problem was that the tv box showed one model number and the online registration and “about” sections showed different model numbers. fixed now and working perfectly. Thanks, again.
