Rechargeable batteries
TheKrell
A mighty and noble race originating on Altair IV.
38,849
46,585
Fairfax, VA
I have been using Eneloop rechargeables made by Panasonic for years. I have four 540 remotes loaded with them and they work just fine.
My oldest friend in town swears by those too. He claims the regular alkaline batteries leak, which I am sorry to say, is occasionally true. He says the Eneloop do not.
tjboston5676
744
1,571
Borger, TX
Rechargeable batteries put out less voltage. For low demand electronics such as a remote, its usually no problem though. However every charge, drain and recharge cycle on the battery slightly depletes it's overall capacity, so if you've had them for a long time they just may not be putting out enough voltage anymore. Also it sounds silly but make sure batteries are in correct way. Most devices batteries alternate direction but with Dish remotes all batteries go in the same direction.
primestar31
13,587
14,101
Beta Omicron Delta III
Duracell alkaline's have had leaking problems for years now. They did something to change them, and I stopped using them after they ruined multiple devices due to leaking. Eveready alkalines do NOT leak.
I can't speak for rechargeable batteries though.
Almighty1
1,261
1,051
San Francisco, California USA
Yes, I wonder how well do the full 1.5v Rechargeable Lithium Ion batteries work in reality.
Almighty1
1,261
1,051
Maybe it has to do with Gillette buying Duracell out, Proctor & Gamble later bought it and it's now part Berkshire-Hathaway, Warren Buffett's company.
Jim5506
8,148
3,513
Slaton, Texas
Every time I buy no-name batteries at a big box store they end up going bad before I use them up, so I always buy name brand - Eveready this last time.
Rechargable batteries are almost always 1.2v. Old zinc -carbon batteries put out 1.5v per cell but NiMH batteries are 1.2v.
Almighty1
1,261
1,051
I wonder if there is a big difference between Eveready and Energizer as they are both under the same umbrella. Rayovac is also part of Eveready after Spectrum Brands sold the company. Rechargeable batteries depends more on the output current than the voltage as many 1.2v will test to 1.4v but Panasonic(formerly Sanyo) Enerloop's are supposedly the best. There is also the high-current versions. Remotes are low drain devices unless you had one of those smart remotes like the one from LG which seems to drain the batteries within weeks.
charlesrshell
SatelliteGuys Crazy
10,972
5,684
O'Fallon, IL
I've had good luck with batteries from Sam's. Usually get the Member's Mark brand, sometimes Energizer or Duracell. They all seem to last about the same time to me.
RTCDude
300
421
San Jose, CA
I don't have any alkaline batteries in my hidy hole. I use nothing but rechargeables. I send less batteries to recycle that
I also only use rechargeables for everything that takes AA and AAA batteries (which is almost every appliance I have). I have a bunch trickle charging all the time, so when one set runs out I just swap. It cost a bit more up front for enough batteries and chargers. But I haven’t bought new batteries in years, and my battery recycle bag have gone to almost zero.
Almighty1
1,261
1,051
Same here except other than my Panasonic Cordless phone which uses my personally custom made/hacked using Panasonic Eneloop low discharge batteries as the replacement packs don't last long, I am actually using all the junk AA/AAA rechargeables and hope they actually die so I can begin using my few hundred Panasonic low discharge and high drain Eneloops including a few pack of Duracell AA Made in Japan Rechargeables which are rebranded high drain Eneloops.
