1/30/2009 5:22pm Uplink Activity Report - 28 changes
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 1/30/2009 5:22pm - 28 changes
Uplink Comparison Range: 01/30/2009 04:47P - 01/30/2009 05:22P
Channel Additions:
281 - BIO [MPEG2 SD] added to EchoStar11 110W TP 05 ConUS beam (NA)
281 - BIO [MPEG4 SD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
282 - HISTI [MPEG2 SD] added to EchoStar11 110W TP 01 ConUS beam (NA)
282 - HISTI [MPEG4 SD] added to Echostar6 72.7W TP 11 ConUS beam (NA)
283 - HMC [MPEG2 SD] added to EchoStar11 110W TP 01 ConUS beam (NA)
283 - HMC [MPEG4 SD] added to Echostar6 72.7W TP 01 ConUS beam (NA)
284 - EDRAM [MPEG2 SD] added to EchoStar11 110W TP 06 ConUS beam (NA)
284 - EDRAM [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
285 - EWAM [MPEG2 SD] added to EchoStar11 110W TP 21 ConUS beam (NA)
285 - EWAM [MPEG4 SD] added to Echostar6 72.7W TP 07 ConUS beam (NA)
286 - ENCOR [MPEG2 SD] added to EchoStar7 119W TP 14 ConUS beam (NA)
286 - ENCOR [MPEG4 SD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
287 - ENCRW [MPEG2 SD] added to EchoStar11 110W TP 15 ConUS beam (NA)
287 - ENCRW [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
288 - EWSTN [MPEG2 SD] added to EchoStar11 110W TP 15 ConUS beam (NA)
288 - EWSTN [MPEG4 SD] added to Echostar6 72.7W TP 09 ConUS beam (NA)
289 - EACTN [MPEG2 SD] added to EchoStar11 110W TP 05 ConUS beam (NA)
289 - EACTN [MPEG4 SD] added to Echostar6 72.7W TP 09 ConUS beam (NA)
290 - EMYST [MPEG2 SD] added to EchoStar11 110W TP 01 ConUS beam (NA)
290 - EMYST [MPEG4 SD] added to Echostar6 72.7W TP 09 ConUS beam (NA)
291 - ELOVE [MPEG2 SD] added to EchoStar11 110W TP 16 ConUS beam (NA)
291 - ELOVE [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
292 - BITV [MPEG2 SD] added to EchoStar11 110W TP 02 ConUS beam (NA)
292 - BITV [MPEG4 SD] added to Echostar6 72.7W TP 23 ConUS beam (NA)
387 - CI [MPEG4 HD] added to Echostar12 61.5W TP 21 ConUS beam (NA)
387 - CI [MPEG4 HD] added to EchoStar5 129W TP 03 ConUS beam (NA)
Channel Removals:
4803 - TMP33 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
4803 - TMP33 (NA) removed from EchoStar5 129W TP 03 ConUS beam
Channels in the system: 6509
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
jself1982
1,272
South Carolina
I would think that is Crimes and Investigations HD by A&E Network on channel 387, I hope they also put it in the 94xx range, I hate the HD's on the lower channels.
nelson61
8,282
7,966
Where it's Warm
Time to keep a close eye on the uplink report. The operating permit for Ciel issued today and they can now use the transponders to transmit to our receivers.
dmendenjr
1,499
The keystone state
(H) Will not show up in the program guide of someone who doesn't sub to the channel - IMHO should be used more often than it is. For Example, Starz Comedy HD. If you sub to starz you will see it in your EPG, if you don't, it won't show up at all.
(A) will show up whether you sub or not.
(NA) is hidden from all subs, mostly there for testing, getting a station ready to launch or place holding.
babcea
214
N.Florida
if you press the guide button 2 times it will only show the channels you sub to.
memo90061
402
Los Angeles, CA
I like seeing the channels I don't subscribe to. Sometimes I look at the channels I don't have and read the info on a program if it sounds interesting. Then I look at the package in which it's at and think if I should get it. lol
theoak
1,089
9
Idaho
You would be the perfect Dish customer then :up
