2 Head LNBF for 61 &72
az99
252
49
Have the 2 head LNBs for the 1000.4 been discontinued? I can't seem to find them anywhere. I have no need for 77º sat.
No such thing. 1000.2 EA has a two head LNBF for 61.5 and 72. 1000.4 never did.
Sorry, I put 1000.4 by mistake. The 2 head for 61 and 72 for EA was what I was asking about.
I use the aiming for the 1000.2 but it is seems to be off a few degrees. But close enough to get started.
I'm confused. I assumed you didn't have the two lnb setup since you were asking where to find it. What dish pointing directions do you use and where do you get them?
I use this http://www.dishpointer.com/ . Select multi LNB then Dish 1000.4 for 61,72,77. It is almost the last on the drop down list.
Those setting get you close if using the 2 LNB head for 61 & 72. IIRC my location showed 187º and it wound up about 180º.
Disregard all the previous posts about 1000.2 or 1000.4 numbering. I was correct to start with as the 1000.4 is the eastern arc. Then someone said otherwise and confused me.
