2 Receivers to 1 Dish
ParaclipseCKu
313
4
Florida Space Coast
Trying to get a feel for the preferred way to use 2 receivers with 1 dish without looping the signal through one of the receivers.
Thanks for any and all input!
FaT Air
HOA Free Zone
Feb 27, 2010
6,668
916
97W 48N
Dual output LNBF (add a multiswitch for even more receivers)
Bandstacked LNBF (minimizes cable requirements -total length) Many times called "one cable solution"
Those are the first solutions that come to mind.
ParaclipseCKu
313
4
Florida Space Coast
Iceberg, I knew I forgot something important! Currently using a single output PLL lnb on the Ku dish. Also only running one cable from this particular dish.
ParaclipseCKu
313
4
Florida Space Coast
FaT Air, Thanks for the input. Forgot about a Bandstacked LNBF! Also trying to keep this to 1 cable for more reasons than anyone would want to read about!
Mr Tony
2,098
8,521
Mankato, MN
If you want only one cable then go with a bandstakced LNB and a satellite grade splitter. Only thing is you will have to rescan the satellite(s) as the LNB LO usually will be different
Magic Static
7,498
4,853
Montana
I share a 10' C/Ku dish and the motor control between two receivers with a diode steering power passing splitter. The downside is you can only use one at a time. But that works fine for my uses.
ParaclipseCKu
313
4
Florida Space Coast
Thanks for the info. The satellite farm here is much bigger than the 1 dish but I figured for simplicity it would be easier not to fact in the other dishes to my question. I'll have to look into the splitter. I knew there would be a few different ways to integrate this into the system!
