SatelliteGuys.US DishNetwork Uplink Report - 3/28/2017 07:27 - 19 Changes
Uplink Comparison Range: 3/28/2017 07:36 - 3/28/2017 07:27 (PST)
Channel Additions:
817 - ORDER [MPEG2 SD] added to EchoStar14 119W TP 10 ConUS (PPV Event Pre-Order)(A) (FP)
817 - ORDER [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS (PPV Event Pre-Order)(A) (FP)
818 - ORDER [MPEG4 HD] added to Nimiq5 72.7W TP 29 ConUS (PPV Event Pre-Order)(A) (FP)
818 - ORDER [MPEG4 HD] added to EchoStar11 110W TP 10 ConUS (PPV Event Pre-Order)(A) (FP)
5258(21) - KRVU [MPEG4 HD] added to Ciel-2 129W TP 05 Spotbeam 16 (Mkt: Chico,CA (CA-MN))(NA)(H)
Channel Removals:
9225 - CW [MPEG2 SD] (NA)(H) removed from EchoStar14 119W TP 20 ConUS (Stn: (MIAMI,FL-CW) (FL-CW))
9225 - CW [MPEG4 SD] (NA)(H) removed from Nimiq5 72.7W TP 31 ConUS (Stn: (MIAMI,FL-CW) (FL-CW))
9226 - CW [MPEG2 SD] (NA)(H) removed from EchoStar14 119W TP 20 ConUS (Stn: (MIAMI,FL-CW) (FL-CW))
9407 - SEC [MPEG2 SD] (NA)(H) removed from EchoStar14 119W TP 20 ConUS (SEC)
9408 - SEC [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 15 Conus (SEC)
9408 - SEC [MPEG4 HD] (NA)(H) removed from Ciel-2 129W TP 28 ConUS (SEC)
MAP Changed:
5258(15) - WICD [MPEG4 HD] Ciel-2 129W TP 07 Spotbeam 24 renamed to WCCU , map changed to (27) (WCCU)(Mkt: Champaign,IL)(A)(H)
7409(15) - WICD [MPEG2 SD] EchoStar14 119W TP 03 Spotbeam B13 renamed to WCCU , map changed to (27) (WCCU)(Mkt: Champaign,IL)(A)(H)
Tier Changed:
5275(12) - KMVT2 [MPEG4 HD] Ciel-2 129W TP 08 Spotbeam 12 changed to Available (KMVT2)(Mkt: Twin Falls,ID)(A)(H)
7813(6) - KGWN3 [MPEG2 SD] EchoStar10 110W TP 04 Spotbeam 30 changed to Available (KGWN3)(Mkt: Cheyenne,WY)(A)(H)
7957(12) - KCWY2 [MPEG2 SD] Ciel-2 129W TP 02 Spotbeam 13 changed to Available (KCWY2)(Mkt: Casper,WY)(A)(H)
8129(14) - KYLX2 [MPEG2 SD] EchoStar10 110W TP 27 Spotbeam 17 changed to Available (KYLX2)(Mkt: Laredo,TX)(A)(H)
8808(12) - KMVT2 [MPEG2 SD] EchoStar10 110W TP 31 Spotbeam 37 changed to Available (KMVT2)(Mkt: Twin Falls,ID)(A)(H)
Name Changed:
9874 - TARAB [MPEG2 SD] Anik F3 118.7W TP 28 ConUS renamed to DMC (DMC)(A)(H)
Transponder Changes:
EchoStar11 110W TP 10 ConUS (21.500 8PSK 2/3) added.
Ciel-2 129W TP 05 Spotbeam 16 (21.500 8PSK 2/3) added.
Echostar16 61.5W TP 15 Conus (21.500 8PSK 2/3) removed.
Ciel-2 129W TP 19 ConUS (21.500 8PSK 2/3) removed.
Nimiq5 72.7W TP 23 ConUS (21.500 8PSK 2/3) removed.
Nimiq5 72.7W TP 31 ConUS (21.500 8PSK 2/3) removed.
Channels in the system: 9676
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2016 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.2
© 2016 - All Rights Reserved - SatelliteGuys Incorporated.
Channel Additions:
Channel Removals:
MAP Changed:
Tier Changed:
Name Changed:
(FP) = Free Preview
