D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/4/2010 2:13pm - 97 changes
Uplink Comparison Range: 03/03/2010 01:32P - 03/03/2010 01:51P
Channel Additions:
5282(19) - KTVE [MPEG4 HD] added to EchoStar8 77W TP 14 ConUS beam (NA)(El Dorado, AR-NBC)
7813(43) - KEJB [MPEG4 SD] added to EchoStar8 77W TP 14 ConUS beam (NA)(El Dorado, AR-MY)
7816(12) - KETZ [MPEG4 SD] added to EchoStar8 77W TP 14 ConUS beam (NA)(El Dorado, AR-PBS)
7604(26) - KGCW [MPEG4 SD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Burlington, IA-CW)
5192(6) - KWQC [MPEG4 HD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Davenport, IA-NBC)
5193(18) - KLJB [MPEG4 HD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Davenport, IA-FOX)
7607(36) - KQIN [MPEG4 SD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Davenport, IA-PBS)
9264(8) - WSIU [MPEG4 SD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Carbondale, IL-PBS)
5150(3) - WSIL [MPEG4 HD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Harrisburg, IL-ABC)
9262(27) - WTCT [MPEG4 SD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Marion, IL-REL)
5190(8) - WQAD [MPEG4 HD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Moline, IL-ABC)
7606(24) - WQPT [MPEG4 SD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Moline, IL-PBS)
5191(4) - WHBF [MPEG4 HD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Rock Island, IL-CBS)
5152(6) - WPSD [MPEG4 HD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Paducah, KY-NBC)
9259(49) - WDKA [MPEG4 SD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Paducah, KY-MY)
9261(29) - WKPD [MPEG4 SD] added to EchoStar8 77W TP 24 ConUS beam (NA)(Paducah, KY-PBS)
5280(11) - KAQY [MPEG4 HD] added to EchoStar8 77W TP 14 ConUS beam (NA)(Columbia, LA-ABC)
5282(7) - KPLC [MPEG4 HD] added to EchoStar8 77W TP 10 ConUS beam (NA)(Lake Charles, LA-NBC)
5283(29) - KVHP [MPEG4 HD] added to EchoStar8 77W TP 10 ConUS beam (NA)(Lake Charles, LA-FOX)
5285(18) - KLTL [MPEG4 HD] added to EchoStar8 77W TP 10 ConUS beam (NA)(Lake Charles, LA-PBS)
5281(8) - KNOE [MPEG4 HD] added to EchoStar8 77W TP 14 ConUS beam (NA)(Monroe, LA-CBS)
7814(13) - KLTM [MPEG4 SD] added to EchoStar8 77W TP 14 ConUS beam (NA)(Monroe, LA-PBS)
5283(14) - KARD [MPEG4 HD] added to EchoStar8 77W TP 14 ConUS beam (NA)(West Monroe, LA-FOX)
7815(39) - KMCT [MPEG4 SD] added to EchoStar8 77W TP 14 ConUS beam (NA)(West Monroe, LA-IND)
5270 - WGGB [MPEG4 HD] added to EchoStar8 77W TP 22 ConUS beam (NA)(Springfield, MA-ABC)
5272(22) - WWLP [MPEG4 HD] added to EchoStar8 77W TP 22 ConUS beam (NA)(Springfield, MA-NBC)
5273 - WGBY [MPEG4 HD] added to EchoStar8 77W TP 22 ConUS beam (NA)(Springfield, MA-PBS)
5274 - WGGBD [MPEG4 HD] added to EchoStar8 77W TP 22 ConUS beam (NA)(Springfield, MA-FOX)
6531(67) - WSHM [MPEG4 SD] added to EchoStar8 77W TP 22 ConUS beam (NA)(Springfield, MA-CBS)
5151(12) - KFVS [MPEG4 HD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Cape Girardeau, MO-CBS)
5153(23) - KBSI [MPEG4 HD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Cape Girardeau, MO-FOX)
8137(40) - WPCB [MPEG4 SD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Greensburg, PA-REL)
8135(19) - WPCW [MPEG4 SD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Jeannette, PA-CW)
6477(4) - WTAE [MPEG4 HD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-ABC)
6478(2) - KDKA [MPEG4 HD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-CBS)
6479(11) - WPXI [MPEG4 HD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-NBC)
6480(53) - WPGH [MPEG4 HD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-FOX)
8134(22) - WPMY [MPEG4 SD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-MY)
8136(13) - WQED [MPEG4 SD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-PBS)
8142(16) - WQEX [MPEG4 SD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-SHOP)
6877 - UP29 [MPEG4 HD] added to EchoStar8 77W TP 30 ConUS beam (NA)
Channel Removals:
7873 - KOZJ (A) (H) removed from Echostar12 61.5W TP 13 Spotbeam 15(Joplin, MO-PBS)
550 - OLYM1 (A) removed from EchoStar11 110W TP 24 ConUS beam
550 - OLYM1 (A) removed from Nimiq5 72.7W TP 29 ConUS beam
551 - OLYM2 (A) removed from EchoStar7 119W TP 18 ConUS beam
551 - OLYM2 (A) removed from Nimiq5 72.7W TP 29 ConUS beam
552 - OLYM3 (A) removed from EchoStar7 119W TP 18 ConUS beam
552 - OLYM3 (A) removed from Nimiq5 72.7W TP 29 ConUS beam
5948 - TP208 (A) (H) removed from EchoStar3 61.5W TP 32 ConUS beam
5950 - TP210 (NA) removed from EchoStar3 61.5W TP 32 ConUS beam
19211 - OTV2 (A) (H) removed from Anik F3 118.7W TP 13 ConUS beam
19222 - IWINO (A) removed from EchoStar7 119W TP 13 ConUS beam
Channel Moves:
374 - FTV [MPEG4 HD] moved from EchoStar3 61.5W TP 31 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam (A)
4271 - FTV [MPEG4 HD] moved from EchoStar3 61.5W TP 31 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam (A) (H)
5304 - FTV [MPEG4 HD] moved from EchoStar3 61.5W TP 31 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam (A) (H)
9531 - DNFYI [MPEG4 HD] moved from Ciel-2 129W TP 27 ConUS beam to EchoStar11 110W TP 13 ConUS beam (NA)
9531 - DNFYI [MPEG4 HD] moved from EchoStar3 61.5W TP 20 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (NA)
Channel Package Flag Changes:
192 - ID [MPEG2 SD] - EchoStar11 110W TP 09 ConUS beam changed package flags (A)
192 - ID [MPEG4 SD] - Nimiq5 72.7W TP 07 ConUS beam changed package flags (A)
581 - JUS1 [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
590 - MAKTV [MPEG2 SD] - Anik F3 118.7W TP 24 ConUS beam changed to hidden from non-subs (A) (H)
591 - LAMNR [MPEG2 SD] - Anik F3 118.7W TP 07 ConUS beam changed to hidden from non-subs (A) (H)
592 - ZHIVI [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed to hidden from non-subs (A) (H)
593 - RLIFE [MPEG2 SD] - Anik F3 118.7W TP 01 ConUS beam changed to hidden from non-subs (A) (H)
608 - ITVN [MPEG2 SD] - EchoStar3 61.5W TP 29 ConUS beam changed package flags (A)
675 - TVJPN [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed to hidden from non-subs (A) (H)
727 - VIDIT [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
728 - RAI [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam changed package flags (A)
730 - RAINW [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
736 - ITVN [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
738 - CTC [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed to hidden from non-subs (A) (H)
742 - ISRL1 [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed to hidden from non-subs (A) (H)
743 - GLI [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed to hidden from non-subs (A) (H)
784 - EURNS [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
785 - VKAIR [MPEG2 SD] - Anik F3 118.7W TP 20 ConUS beam changed to hidden from non-subs (A) (H)
786 - PEOPL [MPEG2 SD] - Anik F3 118.7W TP 01 ConUS beam changed to hidden from non-subs (A) (H)
900 - EURNS [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
900 - EURNS [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed package flags (A)
901 - EURNS [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
901 - EURNS [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed package flags (A)
908 - RAD60 [MPEG AUDIO] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
909 - RADIT [MPEG AUDIO] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
910 - RAIRD [MPEG AUDIO] - Anik F3 118.7W TP 27 ConUS beam changed package flags (A)
Channel Renames:
481 - PPV - EchoStar11 110W TP 14 ConUS beam renamed to NUDE (A)
481 - PPV - Nimiq5 72.7W TP 07 ConUS beam renamed to NUDE (A)
482 - PPV - EchoStar7 119W TP 16 ConUS beam renamed to NUDE (A)
482 - PPV - Nimiq5 72.7W TP 07 ConUS beam renamed to NUDE (A)
483 - PPV - EchoStar11 110W TP 16 ConUS beam renamed to NUDE (A)
483 - PPV - Nimiq5 72.7W TP 07 ConUS beam renamed to NUDE (A)
484 - PPV - EchoStar11 110W TP 02 ConUS beam renamed to NUDE (A)
484 - PPV - Nimiq5 72.7W TP 07 ConUS beam renamed to NUDE (A)
Transponder Changes:
EchoStar8 77W TP 02 ConUS beam 22500 QPSK TURBO CODED 5/6 added
EchoStar8 77W TP 06 ConUS beam 22500 QPSK TURBO CODED 5/6 added
EchoStar8 77W TP 10 ConUS beam 22500 QPSK TURBO CODED 5/6 added
EchoStar8 77W TP 14 ConUS beam 22500 QPSK TURBO CODED 5/6 added
EchoStar8 77W TP 22 ConUS beam 22500 QPSK TURBO CODED 5/6 added
EchoStar8 77W TP 30 ConUS beam 22500 QPSK TURBO CODED 5/6 added
Channels in the system: 6850
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.03.02
© 2010 - All Rights Reserved - SatelliteGuys Incorporated.
Channel Additions:
Channel Removals:
Channel Moves:
Channel Renames:
