605 & 630 Firmware Update Version 04.06
QCK
725
6
Here is a c/p from SD 630 Support on the Canadian site:
Starting the morning of Wednesday February 16, HDDSR 605 and HDPVR 630 receivers will begin to be updated from Current Version 00.13 to 04.06.
The overall usage and look/feel of the system is unchanged with this download. 04.06 includes a few new and updated features along with providing a more consistent and reliable experience.
We’ve prepared some FAQ and detailed information on this update.
When will I receive the update?
The upgrade will be deployed gradually starting the afternoon of February 15. When you see a “Target Version” on line I of System Status (OPTIONS 4-7), your receiver will be upgraded automatically around 2:10AM local time. The upgrade will occur regardless of whether the receiver is left on or off and should take less than an hour to complete.
If your receiver has not been targeted, it is not possible to force the update. All units will be targeted and upgraded over the coming days.
Will all my recordings and settings migrate to the new version?
Yes, with one exception:
- If upgrading from version 00.10, Channel Locks and Favourites lists will not migrate. Refrain from setting these until after the download.
After the download has occurred and the Guide has fully loaded, Check your PVR/Options menu to ensure all Recording Events have the expected “Next Recording” time. If they don’t, simply make a change in this menu and press EXIT to save. The receiver will replan and everything should be scheduled as expected. This will also happen automatically overnight.
What has changed with this download for the HDPVR 630?
Nearly all parts of the software have been refined for a smoother and more consistent experience. Highlights include:
  • Tuning Rebuild – Audio/video are now presented much faster when turning on the receiver, changing channels, or stopping PVR playback. Tuner lockup/phantom recordings have been eliminated.
  • HDD Space Remaining – In response to your feedback, we’ve added the disk remaining bar to the PVR List and PVR/Upcoming menus. The bar has been made more compact and is now colour coded depending on how full your hard drive is.
  • Parental Controls – The experience with Parental Controls enabled should be more stable, with occurrences of the “false PIN” screen reduced and no more “No Data” blocks for programs that cross the GMT boundary.
  • Guide changes – Channel lineup changes (like new channels being launched) will now appear within 60 minutes, or immediately by turning the receiver off and back on. A Front Panel Reset should no longer be required to fix missing or duplicated channels in your Guide.
  • LIVE and 3D programs now have an icon in the Guide. “Live” programs will now be included when selecting “Record new episodes”. Note that these icons do not appear in the full-screen INFO pages.
  • Search Enhancements – Interests Search genres are now sorted in correct alphabetical order when the language is set to French; Programs beginning with accented characters are no longer grouped at the bottom of the results list; and programs with accented characters can now be properly searched.
  • Tune in Satellite Signal – The OPTIONS 4-3-1 menu now provides signal level from both tuners, an indication of signal strength, satellite, modulation, and transponder ID for both tuners. If no background recording is taking place, some values will not be available. This menu is primarily for self installation/dish alignment and advanced troubleshooting. Audio will be lost when exiting the menu, change channels to resolve.
Another c/p:
Technical Notes
Deleting recordings created on the live display channel
Recordings created on the channel you are currently watching cannot be deleted until one of the following occurs:
1) You change channels once. The recording can now be deleted.
2) You start playback of the recording, and then stop playback. The recording can now be deleted.
3) You wait for the subsequent LOD session to be created. The recording can now be deleted.
This only affects recordings created on the live display channel.
Audio Delay when changing channels
Having “Digital Audio” set to “PCM” instead of “Dolby Digital” will cause a 4-5 second delay in audio each time channels are changed. This setting can be adjusted in OPTIONS 4-2.
LOD Program Transitions
When transitioning from the PREVIOUS to the CURRENT LOD session, playback may resume near the “live” position rather than the start of the current program. Use Absolute Jump to quickly jump back to the start of the current program:
Simply press [0], [PLAY] to jump to the start of the current LOD session.
You can also skip back or rewind to get to the desired position.
so far, everything I've read on other forums suggests that the updated firmware is working well...i am thinking I can't wait till the summer to get one
My 630 was thankfully not too terrible (compared to others, anyway) before the update, but it's been solid as a rock since. No reboots, no pixellation, no glitches. Well, except the stupid 'skip backwards the first time you hit skip ahead' thing; but that's just irritating.
I'm pretty happy with it.
