622 on tuner 2 uhf output
dude2
254
I connected my tuner 2 rf output to our home distribution system. It goes into a splitter at the back of the tv and then one more 2 way in the basement to two tvs.
I set the ouput to channel 22 thinking there would be the least loss there.
The picture was snowy on both tvs. Do I need a booster or is the problem that one of the outputs from the 1st splitter is connected to the tv via the antenna in where cable used to go. Regular signal gets to tv via hdmi on tuner 1.
Make sure the tv's and the rf output on the 622 is the same settings. The tv's might be set to cable as that is what you said you had while the 622 might be set to analog. They must all be set to the same type of signal.
The tv I checked out was an old one that has the click tuner, so click on uhf and turn dial to uhf 22.
Make sure you are connected to the UHF antenna input on the TV. Most older TVs with click type tuners have separate inputs for VHF and UHF antennas. You may need a matching transformer to attach the cable to the UHF terminals.
