622 TV2 output problem
rlarryvt
SatelliteGuys Guru
125
Barre, Vt
I've had my 622 running in dual mode for a couple years. no Problem. the other night went to bed, no tv. Checkrd all connections, nothing. got a new cable, now I can see the output on tv2, crappy picture, no sound. kinda like when you have a crappy signal. also no matter what channel i have the modulator(usually air, channel 66) set on, there is no pic. when i scan with the tv it will pick up the signal on channels 40, 59. not the channel i have set in modulator setup. anybody ever see this before? any help would be appreciated.
Check that modulator is set for air/cable to match you set's input. Air and cable are offset above channel 13, which it must be for the modulator.
-Ken
