625 Mirror TV1
sserrano49
22
New Mexico
Hey guys im trying to figure out how to mirror tv1. I read some stuff on mirroring on the 722 but is it the same because i just ran a splitter to mirror tv2 and figured that both tv1 and tv2 would run through the home distribution port. I checked the modulator set up and i should use channel 3 for tv1 and 60 for tv2. The channel 60 works but nothing on 3. Answers would be much appreciated.
A 625 doesn't share the home distribution port for TV1 and TV2 like a 722 does (modulation is the only way TV1 can be hooked up via coax on a 722, where the 625 has a separate TV1 and TV2 coax output).
To mirror TV1, you either need to run RCA cables, or split the "TV CH 3-4 OUT" cable and run that to the 2 TV's
sling receiver 300? please?
issue with satellite installation
