7/16/2016 16:18 - Uplink Report - 34 Changes
Uplink PC
Uplink Report PC
May 31, 2014
707
6
SatelliteGuys.US DishNetwork Uplink Report - 7/16/2016 16:18 - 34 Changes
Uplink Comparison Range: 7/13/2016 23:14 - 7/16/2016 16:18 (PST)
Channel Additions:
5177(10) - WNCTD [MPEG4 HD] added to Echostar16 61.5W TP 24 Spotbeam 05 (Mkt: Greenville,NC (NC-CW))(NA)(H)
5196(25) - WCWW [MPEG4 HD] added to Echostar16 61.5W TP 30 Spotbeam 55 (Mkt: South Bend,IN (IN-CW))(A)(H)
5197(69) - WMYS [MPEG4 HD] added to Echostar16 61.5W TP 30 Spotbeam 55 (Mkt: South Bend,IN (IN-MN))(A)(H)
5256(50) - WCBDD [MPEG4 HD] added to Echostar16 61.5W TP 27 Spotbeam 33 (Mkt: Charleston,SC (SC-CW))(A)(H)
5256(50) - WCBDD [MPEG4 HD] added to Ciel-2 129W TP 09 Spotbeam 44 (Mkt: Charleston,SC (SC-CW))(A)(H)
15945 - KVVU [Guide Data] added to EchoStar10 110W TP 12 Spotbeam 38 (Stn: (HENDERSON,NV-FOX) (NV-FOX))(NA)(H)
Channel Removals:
7094(25) - WCWW [MPEG4 SD] (A)(H) removed from Echostar16 61.5W TP 30 Spotbeam 55 (Mkt: South Bend,IN (IN-CW))
7099(69) - WMYS [MPEG4 SD] (A)(H) removed from Echostar16 61.5W TP 30 Spotbeam 55 (Mkt: South Bend,IN (IN-MN))
7735(10) - WNCTD [MPEG4 SD] (NA)(H) removed from Echostar16 61.5W TP 32 Spotbeam 05 (Mkt: Greenville,NC (NC-CW))
7892(50) - WCBDD [MPEG4 SD] (A)(H) removed from Echostar16 61.5W TP 27 Spotbeam 33 (Mkt: Charleston,SC (SC-CW))
MAP Changed:
5081(47) - LOCAL [MPEG2 SD] EchoStar14 119W TP 16 ConUS renamed to DISH , changed to Not Available , map (47) removed (Dish Network Information Channel)(NA)(H)
5081(47) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 21 ConUS renamed to DISH , changed to Not Available , map (47) removed (Dish Network Information Channel)(NA)(H)
5082(6) - LOCAL [MPEG2 SD] EchoStar14 119W TP 16 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
5082(6) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 21 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
5083(22) - LOCAL [MPEG2 SD] EchoStar14 119W TP 16 ConUS renamed to DISH , changed to Not Available , map (22) removed (Dish Network Information Channel)(NA)(H)
5083(22) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 21 ConUS renamed to DISH , changed to Not Available , map (22) removed (Dish Network Information Channel)(NA)(H)
5084(4) - LOCAL [MPEG2 SD] EchoStar14 119W TP 16 ConUS renamed to DISH , changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
5084(4) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 21 ConUS renamed to DISH , changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
5085(6) - LOCAL [MPEG2 SD] EchoStar14 119W TP 16 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
5085(6) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 21 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
5086(11) - LOCAL [MPEG2 SD] EchoStar14 119W TP 16 ConUS renamed to DISH , changed to Not Available , map (11) removed (Dish Network Information Channel)(NA)(H)
5086(11) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 21 ConUS renamed to DISH , changed to Not Available , map (11) removed (Dish Network Information Channel)(NA)(H)
5087(3) - LOCAL [MPEG2 SD] EchoStar14 119W TP 16 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
5087(3) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 21 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
5088(4) - LOCAL [MPEG2 SD] EchoStar14 119W TP 16 ConUS renamed to DISH , changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
5088(4) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 21 ConUS renamed to DISH , changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
5089(13) - LOCAL [MPEG2 SD] EchoStar14 119W TP 16 ConUS renamed to DISH , changed to Not Available , map (13) removed (Dish Network Information Channel)(NA)(H)
5089(13) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 21 ConUS renamed to DISH , changed to Not Available , map (13) removed (Dish Network Information Channel)(NA)(H)
5090(4) - LOCAL [MPEG2 SD] EchoStar14 119W TP 16 ConUS renamed to DISH , changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
5090(4) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 21 ConUS renamed to DISH , changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
5091(6) - LOCAL [MPEG2 SD] EchoStar14 119W TP 16 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
5091(6) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 21 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
Name Changed:
5151(5) - KCTV [MPEG4 HD] Ciel-2 129W TP 08 Spotbeam 29 renamed to WIBW (Mkt: St. Joseph,MO (KS - CBS))(A)(H)
6751(5) - KCTV [MPEG2 SD] EchoStar10 110W TP 18 Spotbeam 24 renamed to WIBW (Mkt: St. Joseph,MO (KS-CBS))(A)(H)
Transponder Changes:
Echostar16 61.5W TP 24 Spotbeam 05 (21.500 8PSK 3/4) added.
Ciel-2 129W TP 09 Spotbeam 44 (21.500 8PSK 2/3) added.
Echostar16 61.5W TP 09 Conus (21.500 8PSK 2/3) removed.
EchoStar11 110W TP 15 ConUS (21.500 8PSK 2/3) removed.
Echostar16 61.5W TP 32 Spotbeam 05 (21.500 8PSK 3/4) removed.
Channels in the system: 9898
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2016 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.2
© 2016 - All Rights Reserved - SatelliteGuys Incorporated
Probably the slates that were in place in case the Meredith Group didn't settle.
Also, handful of new HD locals switched from SD.
Name Changed:
This is strange. We had the Kansas City CBS channel as our imported channel since we don't have a CBS channel in the St. Joe DMA. However, as of Friday, we now have the Topeka, KS channel. I know that KCTV in KC is a Meredith channel, but why would they switch if KCTV was never blacked out. Are there different rules for channels imported from neighboring DMA's?
Short markets which it is called where you live Dish can import a channel for a neighbor city and has no obligation or commitment in which channel they import. Now saying that Dish would select a significant viewed channel over one that is not
Reactions: Tampa8
We have KCTV from Kansas City is back now, but guide still says WIBW. It is good to know that if they would have blacked out, I still would have had a CBS station. I guess that is an advantage of being in a short market.
Reactions: pattykay
what about in markets like mine where we don't have a cw local only cw satellite feed that the local cable companies use?
My market does not have a CW channel. But we do get a 2 CW feeds one from NY and one from Florida. Check the 6000 range on your menu for something labeled as CW
I was wondering which affiliates Dish is using for CW short markets, with the Tribune stations being blacked out.
The Florida station is labeled as CW I never paid attention. For MY affiliate they use WSBK also in the 6000 range OK I just checked its under the Tribune broadcasting showing the channel was removed
Interesting. In Toledo, Dish used to include WPIX, but I entered a Toledo zip code at dishpromise.com, and it does not show that Toledo is affected by any disputes, so I was wondering if Dish was substituting a different affiliate instead.
In the Traverse City area some people have WPIX as well. I think it depended on when you started service. The bar down the street has WPIX as well. I have a Miami feed labeled as CW when it was there
