722 with 500 antenna - programming?
goofy_american
17
MN
Greetings,
Due to a temporary snafu with satellite alignment and bad weather, I have a 722 receiver hooked up to an old 500 antenna (110/119).
I'm getting programming just fine and even the HD channels are showing up.
What am I missing?
I know they aren't in MPEG4 but they are still displaying fine.
Can someone please tell me what the difference is with the channel layup when receiving programming from a 500 antenna rather than a 1000.4 (other than the obvious Eastern Arc difference).
This is in the Mpls/St. Paul, MN area.
Thanks!
Also, a follow-up.
What would I need to do to be able to receive separate programming on the 722 receiver from the 500 antenna?
Do I run two coax cables from the 500 to the 722? The 722 came with a Dish Plus separator to run 1 coax line from the antenna to two lines into the receiver. Would this work with the 500 antenna?
Thanks!
Most of the HD will be gone
Also, a follow-up.
Thanks!
Since you are no longer receiving 61.5 most of your HD isn't going to be there. In your HD sat locals will be gone as well. If the 500 is a DP then the seperator will still work but if it is a legacy then it will take 2 lines from the dish.
There are several different LNB configurations that will fit a Dish 500. To use the Separator you have to have the DishPro Plus Twin. If it's a regular DP Twin you need to either run 2 lines or add an external DPP switch. Legacy LNBs require 2 lines.
Minor correction; all HD is indeed MPEG4. Only SD is still MPEG2. There's a lot of HD on 110/119, but most locals are on 61.5 and/or 129. Depending on whether or not you have your locals, you may choose to put up a 129 or 61.5 wing dish, running either into that D500/DPP Twin's LNB input. You'd get more reliable signal that way.
Sling and Dish
NFL Redzone qurstion
