8/22/2009 5:09pm - Uplink Activity Report - 31 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 8/22/2009 5:09pm - 31 changes
Uplink Comparison Range: 08/22/2009 04:54P - 08/22/2009 05:08P
Channel Moves:
576 - ZEESA [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
583 - RADIO [MPEG AUDIO] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
584 - SAMAY [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
585 - AAJTK [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
586 - HT [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
617 - ZCINE [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
619 - B4U [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
624 - SHARA [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
659 - DUBSP [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
665 - ZIKR [MPEG AUDIO] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
672 - DANDA [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
673 - MZIKA [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
767 - ABUDA [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
769 - DREAM [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
783 - NORST [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
5834 - TST25 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5835 - TST26 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5866 - TST01 [SD TV] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5867 - TST02 [SD TV] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5868 - TST03 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5869 - TST04 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5870 - TST05 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5871 - TST06 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5872 - TST07 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5873 - TST08 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5874 - TST09 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5875 - TST10 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5876 - TST11 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5877 - TST12 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
Transponder Changes:
Echostar12 61.5W TP 21 ConUS beam 20000 QPSK 5/6 added
EchoStar3 61.5W TP 12 ConUS beam 20000 QPSK 5/6 removed
Channels in the system: 6627
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
INCORRECT !
IIRC, those are all slates (channel moved to 118.7).
Look at the chart made right now - normal channels.
BTW, the tp21 always was on as 8PSK/21500, just didn't include in SI tables.
Makes you wonder...move on a Saturday. The move was from a E3 to a E12 TP...hmmmm....They can't get Echo6 over there fast enough.
Well E3 is over 12 years old. E5 was only 10 years old and it's now toast. E6 is no spring chicken either. They really need a new satellite there long term.
The E-15 satellite is scheduled to be launched near the end of 2010 to the 61.5 W slot so Dish so have a new satellite there and operational in about 18 months.
